Hi Guys,
I have a real problem with bulk diesel fuel transfer in Indonesia. We get a lot of water and contaminents from the filthy fuel barges the fuel supplier uses. It is not an option to pressure them to provide clean fuel as they just don't care. Everybody here has the same problem. We need to have a barge off-loading rate of 2,000 LPM but cannot attain this because our filters are blocking up quickly and constantly. We have water separators but we need to stop pumping every 15 minutes to drain the water out of them. Does anyone know of an automatic drain valve to drain the water from the separator without draining the diesel fuel out at the same time? I just need the water automatically drained so we can continue pumping. All help much appreciated.
