Previous in Forum: Magnetic Centre of Rotor and Motor Hunting   Next in Forum: Multiplication Factor
Cable Size
04/27/2012 7:09 AM
Dear Engineers,
i have a load of 128KW, wire length is 35 M, & load current is 280A. Which i have to use for this application.....
waiting for your responses....
Re: Cable Size
04/27/2012 7:32 AM
...the right cable according to those well-established and widely-used British Standard 7671 protocols!
http://cr4.globalspec.com/search/sitesearch?do=show&sort=textmatchrank&srch=cable%20sizing&order=asc
Duplicated thread? Maybe.....
Good Answers: 181
Re: Cable Size
04/27/2012 10:39 AM
Do you do any cable calculations for yourself? I've just had a look at some of your previous posts.
Good Answers: 169
Re: Cable Size
04/27/2012 11:01 AM
To give you a rough idea, you should use a 300 sq.mm aluminium conductor cable. But also be informed that a lot of rating factors should be applied, before selecting a cable for a given current rating.
Register to Reply 3 comments
electricalexpert65 (1); PWSlack (1); TonyS (1)
