I will start the discussion right on with what is actually the subject: People treat the new LED technology like they treat incandescent lighting and in my opinion this is counterproductive.
Incandescent lamps are, in general, omnidirectional. For many years engineers have tried to design reflectors to direct direct light where needed as efficient as possible.
Now the LED lamps are "in town" - directed light, low power consumption, able to change colors to an almost infinite number. Still people want to use these as...incandescent light bulbs. All large companies are trying to design LED bulbs that are similar to incandescent. $40 for a 400 lm light bulb.....are you crazy? Do people know anything about distributed lighting? Using new technology with old mentality raises a question mark about people being able to adapt, to use resources efficiently, to evolve.
The LED technology truly is amazing. I can have LED strings to circle the entire room, separate LEDs in the different cabinets that come on when the door opens, as in the refrigerator - in this way I won't need 1000 lm in the room, 100 lm should be enough. On a hallway I can mount LED strips on every side, but not to the ceiling. I'll mount them at the waist level; in this way the lighting power requirement is close to minimum while having uniform illumination and it will relieve the stress on the eyes if automated switches are used (personally I agree that automated switches save energy but I don't like when the light comes on very bright and unexpected).
In one room I have been trying 20 5mm LEDs mounted on a breadboard and powered with a mobile phone charger. The results are quite promising. The lighting isn't yet distributed but I have no problem with the lighting requirements for most of the activities and if more light is needed I can always switch on the main light. For bathroom and kitchen somewhere around 100 LEDs would be necessary (with only 20 LEDs you can chop your fingers
How do you use LEDs and what is your opinion on the design of incandescent like LED bulbs?
