Previous in Forum: Electro Magnetic Waves Penetration   Next in Forum: Scaling and Fouling Factor in Condenser of a Power Plant
13 comments
Overcoming Dynamic Load
05/10/2012 11:27 PM
I need to calculate Electrical effort (or HP) required in overcoming a dynamic load of 50Kgf @ 2 Mtr radius.
This is a metal cutting operation by a Milling cutter. Cutter diameter 110 mm , Depth of cut 4 mm , feed 0.2 mm , Tensile of material being cut is 52Kg/mmsq.
Re: Overcoming dynamic load
05/10/2012 11:39 PM
At least we know this is not a homework problem; unless to describe how the information is insufficient.
Good Answers: 1693
05/10/2012 11:46 PM
Why would you need this information? Are you building a milling machine?
05/10/2012 11:59 PM
Maybe for grooving, facing, or finishing flanges?
05/11/2012 1:49 AM
You guessed it right,buddy.
05/11/2012 3:34 AM
Well, the electrical effort will come out as a rate of doing work. There is no rate information in the input data about the metal cutting operation.
Re: Overcoming Dynamic Load
05/12/2012 8:42 AM
Face Mill operating on a Boring Mill?
Less than Half circle Milling? Entering from one edge ?
Cutter RPM ?
Feed 0.2mm-PER CUTTER turn?
Means you are removing max(22/7x110x0.2)/2 = 5mm3/turn? You can work THAT OUT.
Dynamic Load ?--Is the job not stationary - and cutter head Pillar moving at ?
What is the Problem?
mm
05/13/2012 1:08 AM
Face Mill operating on a Boring Mill - No. a machine by itself
Less than Half circle Milling - No. Full circle
Entering from one edge - No. Plunge start.
Cutter RPM - 145
Feed 0.2mm-PER CUTTER turn - 0.2 mm/tooth (half cutter dia) = face width
Means you are removing max(22/7x110x0.2)/2 = 5mm3/turn? You can work THAT OUT - - Pls do with data provided and mention same in KW or HP or Joules.
Dynamic Load ?--Is the job not stationary - and cutter head Pillar moving at -
- Job stationary , Cutter arm turning (hence dynamic load)
05/13/2012 4:22 AM
Use trippining type cutter. Decrease the feed. Work in stages leaving bridges. Use magnates for support for the cut parts. The forces will be within the machines capacity.
if you are a managment professional or youth who wants to start business contact for free help for your project including financial assistance through NGO in and around Pune India
05/13/2012 7:08 AM
I need to know/calculate the hp or power reqmnt to run the machine. The machine needs to be built. It is not an existing piece of equipment.
05/13/2012 9:29 AM
You need restating Problem with Cross sections /Dimensions/ Infeeds sequentially--at least.
I planned complex machining for 20 years. I cannot even visualize what you are looking for.
CNC milling will solve all ----http://www.cncinformation.com/CNCBlog/diy-cnc-tutorial-1-how-to-calculate-steps-per-inch/.
mm
05/13/2012 9:56 PM
Nice to know we share the same passion.
If you give me yr mail ID I can send you AutoCAD/PDF drgs to show my intentions re machining work an proposed method.
Would also like to know yr earlier/present works/activities and yr geographical location.
05/13/2012 10:18 PM
CR4 may not like ID showing.
They prefer internal mails to me - Do that.Shall tell U all
mm
05/15/2012 9:44 PM
In the field of technical matters - especially being purely only technical and without commercial considerations , I dont understand your statement. Anyway , if interested and you have a passion for peculiar technical issues related to a particular expertise , you know where to reach me.
My mail ID is pelicanmachines @ gmail.com.
Let's see now what happens. I mean no ill will and am sure shall not get any.
Register to Reply 13 comments
kirannawathe (1); lyn (1); MUKULMAHANT (3); pelican2 (5); PWSlack (1); Tornado (2)
