Previous in Forum: SPM or IPM on Hydraulic Presses   Next in Forum: LPG Fired Plastic Extruders
Where is the Visual Examination for Pressure Vessels to ASME 9
06/19/2012 1:41 AM
Hi,
Need info. Where performing final visual welding inspection on a pressure vessel to ASME 9 , where is the final visual welding acceptance criteria found.
........and are the following weld processes pre-qualified to ASME 9... STT- Surface Transfer Tension, Para-Tig and Tip-Tig.
Thanks,
Viv Dunn
Pathfinder Tags: Welding
Good Answers: 34
Re: Where is the Visual Examination for Pressure Vessels to ASME 9
06/19/2012 8:37 AM
NO ASME 9. You need to review ASME V Art. 9 and for evaluation Parr. T-988
WP
Good Answers: 34
06/19/2012 9:01 AM
And for Pressure Vessels: ASME VIII (Normally) Div1 UW-35
WP
07/09/2012 7:37 PM
Hi,
ASME Section IX is for welding procedure specification and qualification as well for welder performance qualification, so if you are inspector and testing a welder for acceptance criteria for visual inspection you need to refer to Section IX
BUT, if you are inspecting for actual welding inspection you need to refer to ASME Section VIII Div 1, UW 33 AND UW 35 AND if you need to make inspection after Dye penetrant test you need to refer to appendix 8
you may review following articles for detail information:
Pressure Vessel Dimension Inspection
Pressure Vessel Inspection
regards
Register to Reply 3 comments
