I recently bought an inverter/charger which inverts 12v dc to 250 v AC 50hertz and can also invert 12v dc to 250 v AC.
After some time I discovered my 12v lead acid battery was failing after only working for 30 min. I first thought the charger was not delivering enough current, only to discover that it was outputting 11.88 volts instead of the expected 14 volts.
I checked inside and found four mosfets labelled IRFZ44N 119P TV.
1)what should i do to raise output voltage to 14 volts?
2) what is the minimum current needed to charge the battery, and how can i get it?
thanks
