Previous in Forum: Heat Sinking an LM338T Voltage Regulator   Next in Forum: Low Voltage vs. 600v. Wire Raceway
8 comments
Capacitors Self Healing
06/29/2012 7:08 PM
i have the following case . in power factor, 2 fuses had gone blown, as i know capacitors r self- healing. is that capacitor could work again or not???
i wanna understand more about self healing property. is that mean it will break down and self heal that means it will work again
Re: capacitors self healing
06/29/2012 8:04 PM
There are many different types of capacitors made of all different kinds of materials and configurations...There is a type called a vacuum capacitor(pictured below), that can be self-healing if conditions of over-arc current are not too extreme...Vacuum capacitors use highly evacuated glass or ceramic chamber with concentric cylindrical electrodes....They are extremely low loss and used for high voltage high power RF applications, such as transmitters and induction heating....
http://en.wikipedia.org/wiki/Vacuum_variable_capacitor
http://en.wikipedia.org/wiki/Types_of_capacitor
Good Answers: 88
Re: Capacitors Self Healing
06/30/2012 8:37 AM
Self-healing capacitor is more of a marketing concept, you can see it like -bunch of internally parallelled capacitor segments from which a damaged one sometimes gets auto isolated by fusing-off its connection to good ones- (lol) Does it mean it will work when reconnected at all, and if yes with the same capacity? Not necessarily, and of course not. S.M.
06/30/2012 2:30 PM
that means i can reconnect them again after they blown off 2 fuses.
Good Answers: 88
06/30/2012 2:58 PM
For this self-healing crap to work at all, the capacitor MUST be connected to a source capable to blow the internal "fusing" arrangement I mentioned in my last post. And obviously your normal circuit fuses are not big enough for that. But there should still be some (considerably higher) current protection at first connection, or this "repairing" be done with much lower than rated voltage, the high "short" current should be enough. And remember, it is self-healing only "sometimes", and extended testing should be done on a "healed" one, before relying on it. S.M.
Good Answers: 21
06/30/2012 11:39 PM
A self-healing metal film capacitor uses a thin, evaporated metal layer for one or both electrodes with polypropylene or polyamide (Mylar) as the dielectric film layer. If/when the dielectric fails, a small hole punctures the dielectric between the metalized layers, and the resulting arc vaporizes the metal near the defect, electrically isolating it. Many manufacturers also insert narrowed regions in the metallization that act as fuses to isolate larger regions of the capacitor in case the initial fault is not cleared properly. In practice, a self-healing capacitor may safely suffer hundreds of small failures without suffering a catastrophic failure. The fault is cleared by energy supplied from the rest of the internal capacitor elements with little, if any, additional external current being required. This technology has revolutionized the design and size of modern energy discharge and power factor correction capacitors. Each self-healing fault slightly reduces the total capacitance, and a 5% reduction in total capacitance is typically considered the point where the capacitor is approaching its end of life.
However, if your capacitor has caused an external fuse to blow, it apparently suffered from a catastrophic overvolting event that may have overwhelmed the self-healing mechanism, creating a permanent short circuit. If this is the case, your capacitor must be replaced.
Stoneridge Engineering - Wreaking Havoc with Electrons for over 40 Years!
07/01/2012 10:19 AM
GA your answer is exactly what I would have said LOL
Good Answers: 804
07/02/2012 4:12 PM
Excellent response.
Popular Science - Weaponology - New Member Canada - Member -
Location: In the sticks of the Central Kootenays, BC, Canada
06/30/2012 11:56 PM
My understanding of self-healing capacitors is related to the lower voltage 480V types.
They are a wound capacitor with a mylar or similiar plastic insulation between the plates. To keep the capacitors compact and low cost, the insulation is very thin and will deteriorate over time. The capacitor is designed that when a section of the plates short together they blow this area of the capacitor to "open" so that the capacitor, over time, still works but slowly loses capacitance. This makes for an interesting maintenance check--we have found capacitors happily functioning but only drawing 30% of their nameplate amperage.
If you have a self-healing capacitor that is blowing fuses that are correctly sized for the capacitor it is toast-replace it.
Jon.
Register to Reply 8 comments
BertHickman (1); Electroman (1); JRaef (1); ramydiab (1); sawmilleng (1); SimpleMind (2); SolarEagle (1)
