Previous in Forum: UPS Batteries - Hazardous?   Next in Forum: Sine Wave to Square Wave Converter Power by 12-18 Volt
Power Calculation
06/30/2012 3:30 PM
How to calculate motor kw for hyd system pumps for its pressure and flow
pradeep
Re: power calculation
06/30/2012 3:49 PM
Pressure times flow, times a constant depending on the units being used.
Good Answers: 48
06/30/2012 5:33 PM
Flow times Pressure times SG over Constant times Pump Efficiency. Constant depends on units. Loads of websites give the formula.
Good Answers: 1693
06/30/2012 4:26 PM
Re: Power Calculation
07/01/2012 4:48 AM
Oh, I would take the volumetric flowrate, multiply by the pressure rise, and divide by the pump's efficiency, Boss, unless the pump manufacturer's technical data sheet doesn't give the motor size for the pump, which is extremely unlikely.
Good moaning!
Register to Reply 4 comments
Crabtree (1); Holzfeller (1); lyn (1); Tornado (1)
