I just bought a small (5000) gallon above ground pool. I live in a latitude close to that of St. Louis. I am wondering if any of our members has used solar heating for a pool, and has any tips regarding it. I am inclined to design my own. I am thinking of using spiral(s) of black corrugated plastic, pool type, hose, laying on the ground. I would run the pool skimmer line, through the whole line, to the pump. I have 1/2 H.P. pump. Is there a length limit to how much it could pump through? The friction through the spirals would be great. Would I need to upgrade the pump? Maybe to 1 H.P.? My objective is to lengthen the swimming season. I am already using a solar blanket. We like the water at 85 to 90 degrees or more. I have lots of room for pipe that would be partially hidden behind the pool (slightly above the pump level). I was thinking of using plastic ties, and/or some kind of framework to keep the pipe neat. Would a clear plastic cover, over the hose, benefit the system much? How much pipe would be advisable? I could lay the whole thing on a black tarp also.
