Hi Everybody. I'm in a bit over my head, so thanks for your help.
I was thinking about putting together an hydraulic circuit to lift my house. I've done plenty of this work with bottle jacks and thought it might be time to step it up a notch with the real deal. So far, I have been able to decipher that a 4" cylinder at 2500 psi is the equivelant of 15 tons of list. So far so good, that's what I' shooting for - 4 to 8 15 ton hydraulic cylinders to lift the house. I figured out what a power unit even is, component wise, and also what a sppol is and the different types. I figure a double acting spool (and cylinder) with a spring return to center would be perfect. I get that you configure the 4 to 8 spools in series and I understand how that works.
I'm wondering what size motor, displacement of pump, and more. I'm just not real clear on the rest. Any help would be beyond great. Thanks.
