I want to replace automatic garage door with insulated wall to convert the garage to a play area. I will build up a wooden floor with 2x6 frame plus insulation inside over the concrete garage floor.But what to do over the concrete floor at the entrance?How to make an insulated ( 2x4 wooden frame) wall over the concrete base which is close to ground level? I need to have atleast 6 inch square concrete beam over floor at entrance ( to join the beams on sides)and should bond with base too. It is not load bearing wall and no need to break the concrete to do a foundation. A sketch will help. It is an Independent house in NJ, USA ,with bedroom over garage. You can give some website references. For such small job I do not want to enage an Architect.
