Previous in Forum: Worlds Strongest Materials   Next in Forum: Shop Inspection Requirements for Gas Turbine
25 comments
Rust Worms
07/09/2012 1:12 PM
Below are pictures of a SS lock plate with rust deposites. Plate was installed on ocean front door frame. I believe the rust is not from the SS plate. I presume some steel residue from using the wrong burnishing brush. What I'm curious about is the "worms" that are found on every deposit on the plate. Anyone know what they are? Magnification is 20X.
If you die in the south - going up or down - you have to go through Atlanta - and there will be a layover.
Pathfinder Tags: rust
Good Answers: 295
Re: Rust Worms
07/09/2012 1:22 PM
Looks like tin whiskers. This is usually associated with electrical components, but that is what it looks like.
Is the lock scalp truly stainless? Judging the stain lapping over the screw (is the screw stainless? Flat head screw indicates it is at least 40 years old) it appears to be rundown as opposed to direct corrosion. This may source from a ferrous component somewhere inside the lock chassis.
Re: Rust Worms
07/09/2012 1:42 PM
Thanks for the response. I'm am some what familiar with tin whiskers - though years ago. Thought there might be a similar phenome with SS. The screw is stainless and is about 2 years old. Based on report back from supplier the plate is stainless. The ferrous component is a by-product from the burnishing process and or sloppy manufacturing steps. I was just curious about the strange growth on the rust. Some close ups show the worms embedded.
Good Answers: 295
Re: Rust Worms
07/09/2012 1:55 PM
"Some close ups show the worms embedded." Yes, I see them. They look like tin or zinc whiskers.
If you are certain all components of the lock are SAE 316 stainless, I don't know what to tell you.
As SolarEagle says, might be adhesive tape fibers.
Re: Rust Worms
07/09/2012 1:25 PM
Looks like duct tape residue, has somebody been taping the lock for easy access?
Good Answers: 150
Re: Rust Worms
07/09/2012 3:13 PM
Probably bacterial mats causing crevice corrosion under them.
Who is John Galt?
Good Answers: 1693
Re: Rust Worms
07/09/2012 4:03 PM
Don't know about mats.
Could the "worms" be microfibers pulled off something by the rough surface of the anomalous area?
Good Answers: 295
Re: Rust Worms
07/09/2012 4:13 PM
Tom, we are working with the word 'worms'.
Are these (as I have assumed) inorganic vermiforms, or are the wiggling about?
Re: Rust Worms
07/09/2012 5:07 PM
Possibly "worms" was a bad choice. Let me change that to Fibers. To my recollection - they have not moved yet. However, look organic. I'm leaning more towards a metal fiber like steel wool. Two more shots different nodules.
Good Answers: 150
Re: Rust Worms
07/09/2012 5:23 PM
trust me, it is MIC...
Who is John Galt?
Re: Rust Worms
07/09/2012 4:40 PM
Ah the tests are back from the lab...it appears to be microbiologically induced corrosion....
"Failure Analysis:
Sample 1, 2 and 3 failed due to microbiologically-induced corrosion (MIC). Metallographic results show that the pitting initiated from the ID. The pits were deep and narrow, like tunnels. This morphology is suggestive of microbiologically-influenced corrosion.
ID Deposit Analysis: The corrosion products contained constituents of the stainless steel tube (Fe, Cr, Ni). Relatively high carbon and sulfur point to the strong possibility that the wastage is from microbiological activity. Plus, a relatively high amount of soluble sulfate was detected, indicating the presence of sulfur-reducing bacteria (SRB). Carbon was likely from organic matter and acts as a nutrient for microbes. The by-products (hydrogen sulfides, tubercles, ammonia, organic and inorganic acids) released by the bacteria growth create favorable conditions for corrosion. Chloride anions cause pitting and SCC in austenitic stainless steels."
http://davidnfrench.com/Microbiologically-Induced-Corrossion/-SS-Pipe.html
Good Answers: 150
Re: Rust Worms
07/09/2012 4:53 PM
Toldjaso! =b
Who is John Galt?
Good Answers: 109
Re: Rust Worms
07/09/2012 11:21 PM
Both you and Rorschart get GAs. I submitted another answer before reading all the posts but I too think MIC. SRB are not likely on the surface of the lock as they are obligate anaerobes. They could have some anaerobic niche underlying the mat of iron where SRB could survive. These tubulars of iron protect the bacteria from disinfection like chlorination.
Australia - Member - New Member Hobbies - Target Shooting - New Member Popular Science - Weaponology - New Member
Re: Rust Worms
07/09/2012 6:42 PM
Tom,
I don't know about the worms... but to me, the rust appears to be coming from the screw holding the striker plate to the door frame.
When I enlarged the photo, it looks like a "negative screwhead" shaped mark directly above the screw in the lock plate.
Just my observation so I could be wrong...wouldn't be the first time.
Regards,
Sapper
It's all about the Boom! - MythBusters
Re: Rust Worms
07/09/2012 11:00 PM
i'm not sure if this applies to your situation. lately i watched a documentry about the titanic. there were "rustcicles"growing on the metal parts of the wreck.
there explaination was that it was caused by a microbe? that feeds on metal and makes formations that look like stalegmites. it is a living organism.
Good Answers: 109
Re: Rust Worms
07/09/2012 11:10 PM
I am assuming that the ocean front door is exposed to a lot of potential water. And if so, then my suspicion is that the "worms" are really bacteria, Filamentous iron bacteria. These are individual bacteria that will extend themselves in tubular iron pipes. Viewing them at 20x magnification would be sufficient. They are faculative in that they can live in aerobic or anaerobic conditions. The filaments can be very long and become matted. I would be sure except for explaining a food source. Is the lock on a fish house? I am searching for an food source answer and a fish house would be an area where dirty hands may handle the lock frequently. The iron source could easily be from the stainless.
These are some of the same bacteria that will make the Titanic disappear in the near future.
Re: Rust Worms
07/09/2012 11:59 PM
thank you for repeating my post.
Good Answers: 109
Re: Rust Worms
07/10/2012 9:28 AM
Sorry durtieduck. I think I need to read all the posts before submitting. But you are right on the money with regard to the Titanic. Roy Cullimore, a university of Saskatchewan prof, ground water microbiologist and author, visited the site and was amazed by the biological corrosion. I have been involved in the ground water and microbiological field for years. I think bacteria can explain a lot of the geochemistry and geology. In the case of the lock, we get a chance to observe some of the bacteria in action. (These bacteria are not to be confused with coliform bacteria and would not show up on such testing).
Good Answers: 102
Re: Rust Worms
07/10/2012 12:30 AM
OP, does a magnet adhere to the lock?
The shape of that rusted area looks like a zinc plating has flaked off.
You only have the supplier's word on whether it is or isn't stainless.
Magnet is a quick check. Magnetic stainless (<312 ?) will still rust.
Good Answers: 32
Re: Rust Worms
07/10/2012 4:41 AM
From the looks, it could be that the "latch" from the door, un-pictured, could be steel and be the cause of rusting due to a minute electrolytic action of dis-similar metals in a salty/moist air environment. This also could give a basis for MIC growth as mentioned by others earlier.
Re: Rust Worms
07/10/2012 7:55 AM
Thanks all for the interesting responses. To respond to some of the questions/inputs - The plate is none magnetic, The lock plate is on a beach condo and it is possible some organic substance was deposited on the plate. There is no rust or corrosion on on any other part of the lock. The frame the lock is contained in is aluminum - Electrolysis would presumably attack the least noble metal first. In all my experiences with rust on faceplate's I will see salt crystals embedded or in close proximity of the rust. On this specimen I do not see the salt crystals. The screw when removed shows only some rust on the ridge of the head.
Re: Rust Worms
07/10/2012 12:10 PM
Most latch bolts in these type of locksets are nickle plated brass or stainless steel. What is possible is the shaft holding the latch & return spring is corroding and intruding upon the surface of the face plate. JUST A THOUGHT.
Re: Rust Worms
07/10/2012 1:02 PM
The striker plate and latch are all SS. Though the lock latch hook makes contact to the keeper plate the opposing rusted plate is separated apart by 3/8 Poly Urethane bumper. There are no complaints about the keeper plate.
Re: Rust Worms
07/10/2012 3:50 PM
It is not the strike plate that I am speaking of . It is the mild steel shaft that comes out of the back of the SS latch that the return spring sits on this is not SS. It is where the spring sits and it can corrode when the moisture is high enough IE condensation with the temperature difference inside to outside you will get moisture and it tends to go out any way it can. this has been an issue for some time in the midwest due to the manufactures not lubricating these parts. Due in part from the manufactures cheapening things. And since we can not air ship anything with the type of lubricants that tend to be used in these parts have been deemed highly flammable according to FAA. Hince we can't air ship unless there are no lubricants used in these items. And do you think a contractor thinks of lubricating these items in the field not very often that I have found. Since I get to repair a lot of this type of hardware in the field almost all related to non lubrication. I've rattled on long enough, somebody around here has to work today. Duke
Re: Rust Worms
07/10/2012 4:04 PM
Okay - I understand. Thanks for the response.
I checked out the insides - no corrosion of any kind there and there was lubrication - go figure.
We have thousands of these out in the field, mostly beach front, that don't exhibit this problem. We have replaced this one and will wait and see what happens. Most likely wont see it again at this site.
Good Answers: 295
Re: Rust Worms
07/10/2012 4:07 PM
I sort of suspect Rorshak Rorschatch Rorhscah the ink blot guy is correct. Makes the most sense after I consider.
Register to Reply 25 comments
Doorman (4); durtieduck (2); kendall (1); kevinm (3); LOCKDUKE (2); lyn (1); Rorschach (3); Sapper (1); SolarEagle (2); tom@windoor (5); Wal (1)
