I made a circuit comprising of x-capacitor + resistor / bridge rectifier / elecrolytic capacitor / resistors in each string to limit current to drive the white LED array 5 mm leaded. The aim was to drive 140 leds made in 4 strings of 35 LEDs. The voltage was set at 3.2 v per LED and a current of 20 mA. The design appeared correct and everything is working. After 10 days (240 hours) of continuous usage (24x7), I notice a significant drop in the brightness.
when measured the voltage and currents are at the same ratings. Where have I gone wrong (or) is it the characteristics of the LED to fade ? How can I correct this problem?
Thanks for the support in advance.
Madhav
