I'm looking for advice on the best process to go through when bringing a dormant engine back to life.
I have a 1982 Chris Craft Boat, which is now almost completely restored. The boat has a stern-drive engine - GM 350 cubic inch small block and Mercruiser outdrive. The engine was completely rebuilt, and all external parts (manifolds, carb, ignition, fuel system, water pump, alternator, starter) replaced or rebuilt. The engine work was done in 2000. The restoration work started in 2001 and has been a painstaking 8-9 year (vacations and weekends) project.
Now, it's time to do something about the engine - which ran fine for 45 minutes before the boat hull split open on rocks...
... which lead to the restoration project.
The engine has been in the engine compartment for 10 years, covered and protected from rain and freezing.
What steps would you recommend I go through before trying to start the engine?
Some things I know I will need -
1) New starting battery
2) Clean fuel and fuel filter (the tank is welded aluminum and has been flushed, there are no gaskets or seals to replace, and all the fuel lines are new)
3) new water pump impeller in the outdrive
4) new bellows and thrust bearing - probably
Any tips on how to get the engine running while minimizing any "set-up" damage would be great help - I'm looking for ideas on whether I should pull the entire engine and re-hone everything; or pull the spark plugs and fill the cylinders with (some kind of?) oil and let it sit for a day and hand-crank (x number of revolutions); or run 30 seconds, then change oil and filter again; to ???
Thanks!
TX
