Previous in Forum: Ansys WB Nonlinear Problem   Next in Forum: Painting on an Existing Paint Which is as Per Spec is OK?
Isolating Spool
08/08/2012 1:40 AM
Can anyone throe some light on, y we use isolating spool , rather than isolating joint,
what shoul be the real basis for this spool selection and how much should be the isolating spool length
Re: isolating spool
08/08/2012 3:16 AM
Without some real, solid information, illumination will not be forthcoming.
  • Is asking the individual that designed the installation out of the question? If so, why?
Re: isolating spool
08/08/2012 6:55 AM
Do you mean blind flange? However, using isolating spool is to make sure 100% isolation. Other isolation methods like joints or valves might have leakage or pass from the seat so it is not 100% isolation, especially if there is hydrocarbon or dangerous materials to be isolated
Register to Reply 2 comments
