Previous in Forum: Line Losses Percentage   Next in Forum: Is it possible to Use Super Capacitors to Increase a Li-Ion Battery's Run Time?
Ceiling Fan Speed
08/28/2012 5:35 PM
How can I increase my fan speed without buring up the motor?
Good Answers: 295
Re: ceiling fan speed
08/28/2012 5:39 PM
Remove the fan blades.
08/28/2012 5:53 PM
Variable Frequency Drive...
08/28/2012 6:07 PM
Some sort of gearing system.
The simplest of which would be a belt driven gear, but you would need to move the fan blades and manufacture another support shaft
Link
Likely too expensive for your application thou.
Good Answers: 804
Re: Ceiling Fan Speed
08/28/2012 7:07 PM
CAUTION
A Ceiling fan will be a centrifugal fan, so the load on the motor will increase at the CUBE of the fan speed change. For example if you increase the fan speed by 25%, the motor loading will increase to 1.253, or 195%. So if you have a 1/4HP (186.5W) motor as is typical in many ceiling fans, the LOAD on that motor will become almost 1/2HP (364W) and the motor will burn up, or trip off line if you are lucky and the motor has thermal protectors built-in. But some do not, so the dumb animal fan motor will try to push that extra air until it dies / fries.
So how can you increase your fan speed? Buy a faster fan with a bigger motor designed to move more air.
08/28/2012 9:39 PM
i agree. shorter fan blades would defeat the purpose also. more efficent fan blades would'nt be a practical solution. there's no free ride.
the motor windings are specifically wound for three speeds and a certain power output
the obvious solution is to replace the fan with one that has a higher wattage rating and a higher cfm circulation factor.
08/28/2012 11:37 PM
Thank you for your input. I'll need to get a new fan!!!
Register to Reply 6 comments
Doorman (1); durtieduck (1); francisair (1); jack of all trades (1); JRaef (1); SolarEagle (1)
