Previous in Forum: Conversion of Air Compressor Motor Controller from Wye-Delta to VFD   Next in Forum: Chilled water quality
13 comments
Bearing Number
08/30/2012 4:14 AM
At the time of maintenance work we found a damage bearing without any number. It's a needle bearing with ID: 13, OD: 30 & Depth: 62 mm. How can I calculate bearing number?
Experiance will come with time, but you have to manage quality time. Bad management always leads us bad experiance.
User-tagged by 1 user
Re: Bearing Number
08/30/2012 4:29 AM
Off what make and manufacturer's equipment has it fallen?
Re: Bearing Number
08/30/2012 4:37 AM
its an old blister m/c bearing, and we did not have any reference for that parts.
Good Answers: 18
Re: Bearing Number
08/30/2012 4:57 AM
Hi bashir01219,
I don't think it's possible to work out a bearing number, but, give the dimensional details along with number and size of the needle in your bearings and I'm sure your local bearing distributor will be able to help you.
Best regards,
John
Best advice I can give as you get older "Never miss an opportunity to relieve yourself"
Re: Bearing Number
08/30/2012 7:15 AM
Thanks.
ID, OD & Depth is not enough?
Good Answers: 18
Re: Bearing Number
08/30/2012 7:35 AM
Hi bashir,
It might be, but the more information you can give a supplier the more likely he will be able to give you what you want.
Best refards,
John
Good Answers: 266
Re: Bearing Number
08/30/2012 8:12 AM
May want to supply the rpm at which it operates.
Re: Bearing Number
08/30/2012 11:40 PM
Re: Bearing Number
08/31/2012 2:40 PM
They may want some estimate of the speed of the shaft and the load. -- JHF
Re: Bearing Number
08/30/2012 11:57 PM
devitg
Re: Bearing Number
08/31/2012 1:02 AM
contact timken bearing co. you'll need a digital calibre to measure the bearing.
od. id, and needle length and diameter.
if they don't have it, no one does.
good luck
Hobbies - CNC - New Member United States - Member - New Member
Re: Bearing Number
08/31/2012 7:20 AM
Measuring the ID of a needle bearing can be difficult. Measure the shaft OD to get the bearing ID.
Bearing ID, OD, and length gets you most of the way there. Also tell them if there are any seals, operating speed and working environment. There are also different styles of needle bearings such as caged and full complement. Some do not have the outer race. If possible take the bearing to the supplier so they can match it up. If not possible then have it in font of you while on the phone so you can describe it fully and answer their questions.
In order to provide a part number you would have to know the product line of a particular manufacturer such as Torrington.
Hobbies - CNC - New Member Engineering Fields - Mechanical Engineering - New Member
Re: Bearing Number
08/31/2012 1:21 PM
Are you sure that you have the dimensions right? 13mm id x 30mm od would be quite uncommon. maybe 30mm id x 62mm od x 13 width would be more "normal". Checking some of the size listings don't show that much spread between the id and od.
Check timken.com size listings page 139 for needle type roller bearings.......Good Luck
Re: Bearing Number
09/01/2012 2:40 AM
There are cross referance cataluge which will help in this case. If you give the dimintions of the bearing you will get several companies which produce the same size each company has its own number.
It is not possible to get the commercial unique part number from the diminssions for all manufucturers
Register to Reply 13 comments
bashir01219 (2); Circuit Breaker (1); devitg (1); durtieduck (1); jesw55 (2); Mohammed Badros (1); ozzb (1); PWSlack (1); rastovsh (1); The Mechanic (1); the wrench (1)
