Previous in Forum: HVAC Information   Next in Forum: Risk Based Inspection for Pressure Vessel
6 MO Austenitic Stainless Steel Tube Fittings
09/02/2012 10:30 PM
Hi all,
I am looking for hydraulic steel tube fittings, cone and threaded connection bulkhead for pressure rating 10000 psi (517 bar) in 6 MO Austentitic material. The alternate to this material is 254 SMO material. Kindly help me to know, if this material is available in the market? has anybody used this before?
Pathfinder Tags: hydraulics
Re: 6 MO Austenitic Stainless Steel Tube Fittings
09/03/2012 10:53 PM
Hi,
I am Penny and I am a tube fitting manufacturer in China. Also,I have resources in 6 MO Austentitic material & 254 SMO material. If you are interested in contacting with me. Please send an E-mail
CR4 ADMIN - email address removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers and email addresses posted in threads or comments. You can share this information via the CR4 internal messaging system.
Good Answers: 59
09/04/2012 7:50 AM
Try GlobalSpec - you can enter all of your specs into the filter on the left-hand side of the page.
09/04/2012 8:47 PM
Hi,
Pls check with M/s Petrotech or Supertech for Parker or Swagelok fittings.
03/06/2013 7:08 AM
You can try The Alloy Valve Stockist, they specialize in that alloy grade.
Working with corrosion-resistant valves for the petrochemical industry.
Register to Reply 4 comments
mohammedyassar (1); pennyvalve (1); pfeinstein (1); SavvyExacta (1)
