Previous in Forum: Neutral Earthing for K-Rated Transformer   Next in Forum: Number Earth Pit
10 comments
85 dB(A) of Sound
09/25/2012 5:39 AM
Hi,
can i get help on how to understand 85 dB(A) of sound level in terms of decibels (dB)? So far, I only understood that it is A weighted decibels. Is there any conversion formula?
Regards,
sks
Good Answers: 181
Re: 85 dB(A) of sound.
09/25/2012 6:07 AM
Compare them using the Henweigh system.
Good Answers: 918
09/25/2012 6:31 AM
What does the weight of a hen have to do with this? :)
Good Answers: 34
09/25/2012 6:14 AM
You can understand 85 dB... by studying THIS
Good Answers: 918
09/25/2012 6:29 AM
The A-weighted system reduces or "corrects" the sound pressure values (in dB) for lower audio frequencies. This is done to better match the actual hearing performance of the human ear at frequencies below 1kHz, where human sensitivity diminishes as compared to frequencies above 1 kHz.
United Kingdom - Member - Hearts of Oak Popular Science - Paleontology - New Member Engineering Fields - Mechanical Engineering - New Member
Good Answers: 75
Re: 85 dB(A) of Sound
09/25/2012 7:43 AM
What are you doing with the number after you have understood it? If you are comparing it to a legislative limit, you will need to ensure you have the correct weighting. If you're looking for the source of an annoying noise, then sometimes A-Weighting is better since, as AH said, it gives a better approximation of the human ears' response than does the raw logarithmic scale.
Chaos always wins because it's better organised.
Good Answers: 84
09/26/2012 1:13 AM
You rock, ER.
Good Answers: 75
09/26/2012 3:46 AM
Something to do with my previous life as a sound engineer...then a noise (NVH) engineer! Ah the joys of shaking the lighting engineers off their ladders by playing Tom Sawyer at full power through the FOH stack at the end of the sound check...I love that first chord
Good Answers: 1693
09/25/2012 9:15 AM
There is no conversion formula.
As ER says, why do you want to know.
If you are sampling sound as it relates to the human ear, it's A weighting.
If you are performing research on the source of sound using sound pressure level (SPL) readings one of the other scales may be more appropriate. Just depends.
A-weighting - Wikipedia, the free encyclopedia
Good Answers: 102
09/26/2012 12:55 AM
There is no correlation.
One is a power and the other is a ratio.
If you increase 85dBA by 3 dB then the result is 88dbA
85dBA + 85dBA = 88dBA
09/26/2012 1:15 AM
Register to Reply 10 comments
129CBRider (1); Anonymous Hero (2); English Rose (2); europium (1); Joshi (1); lyn (1); TonyS (1); Wal (1)
