A 10" pipe supply dry air to a plant 2 km away at 20 to 30 barg pressure. There is a 100 cu.m buffer vessel also before the plant. A turbo-compressor can feed 10000 Nm3/hr to the pipe at 30 barg. When pressure was 30 barg, this 10" pipe weld joint suddenly failed at entry to the plant and whole air started venting to atmosphere. Compressor was stopped after 7.5 minutes. I wanted to know:
1. What will be the air velocity at the point of failure? Will it decrease linearly with time?
2. How pressure will fall at the end point from 30 barg to zero in about 10 minutes? (At compressor discharge pressure dropped from 31 to 20 barg in 75 sec, from 20 to 15 barg in next 1 min, from 15 to 10 barg in next 2 min, from 10 to 5 barg in next 3 min...... then stopped)
3. Volume of piping is around 100 cu.m, including a buffer vessel, total volume is 200 cu.m. What is the total quantity of air vented to atmosphere?
