Previous in Forum: Actual External Pressure When Subjected to Vacuum   Next in Forum: Inner and Outer Mold Line Definition in Sheet Metal Operation
Welding Question
10/04/2012 3:11 AM
We are welding 4140 tube of wall thickness 13mm to S275JR plate. E7018 is the electrode and the process is SMAW. can anyone give the procedure,pre heat and post heat temperatures.
Thanks in advance.
"Let my body and its pain take care of each other, thou my mind will always be in a bliss"
Good Answers: 34
Re: Welding Question
10/04/2012 9:29 AM
ASTM 519 grade 4140 carbon steel alloy?
10/04/2012 12:29 PM
yes. ASTM 519 grade 4140 carbon alloy tube...........
Good Answers: 34
10/05/2012 1:49 AM
OK, According to ASME IX (2010 Edition) QW-422, All SA 519 are P1 and S 275JR is more/Lees the same ASTM SA-36, another P1. Then, you only have to Pre-heat to remove moisture. For thicknees 13 mm you need no PWHT.
For the others variables of this welding process (SMAW) go to ASME IX QW-253
Register to Reply 3 comments
