Previous in Forum: Single Phase Generator   Next in Forum: Relation Between Pressure and Kinetic Energy
10 comments
Good Answers: 181
A Bit of Help Needed from the Elders
10/10/2012 6:58 PM
I have just finished a drawing for a 6 phase Mercury Arc Rectifier. Could some of the older members check it over for me, I've done it from memory and the scant bit of information I can find.
For obvious reasons I don't want to put it in open forum. So if you could help can you contact me by PM.
Re: A bit of help needed from the elders.
10/10/2012 10:16 PM
I've only ever seen one of these and it was a "BEAST" for a coal mine, but only three phase.
The reason I'm putting this up is that one of the impressive things about it was the necessary isolation from people and living things. It was encased in a housing of lead bricks due to "radiation" issues that I'm sure you will understand.
From memory it was 1100Amp capability to supply mining and winding equipment at the mine.
Over 30 years ago and I have no idea what teh circuitry was.
Good Answers: 181
Re: A Bit of Help Needed from the Elders
10/11/2012 5:16 AM
This is the type I used to work with, British Thompson Huston 500A 220V. They've had me fascinated ever since.
Good Answers: 73
10/11/2012 12:41 PM
That thing looks a little bit like a three phase fluorescent lamp I once made. But I didn't draw off any DC power.
Good Answers: 120
10/11/2012 11:18 PM
on the web I found many like this.
http://tinyurl.com/8bj855t
http://www.vintage-radio.net/forum/showthread.php?t=53442
Re: A rather nice German website
Hi Gents, 6 phase rectification is quite common, it is achieved using both a Star and a Delta secondary on the same transformer (often know as 6 pulse rectification). The direct output from the rectifier only has 4% ripple and is frequently used without any smoothing caps if a batttery is on the line (Aircraft transformer rectifier units).
Modern aircraft now use 18 pulse or higher rectification all in the name of reducing harmonics and improving power factor (at the expense of efficiency)
Ed
Per Ardua Ad Astra
United Kingdom - Member - New Member Engineering Fields - Transportation Engineering - New Member Technical Fields - Marketing/Advertising - New Member Hobbies - Target Shooting - New Member
10/12/2012 4:05 AM
6 and 12 phase mercury rectifiers were used for many years in railway traction supplies. In the mid 80s I worked with the the silicon diode replacements that were being built for the London and Glasgow undergrounds.
10/12/2012 3:36 AM
Good Answers: 181
10/12/2012 4:45 AM
i've been trying Google for years, lots of nice pictures but no "real" information.
This is why I asked if any of the older members had the "know how" on them. It's 35 years since I last worked on them and the memory isn't what it was.
10/12/2012 9:44 AM
I am not sure what you want specifically.
Would this help?
http://ia600305.us.archive.org/25/items/principlesofmerc00prin/principlesofmerc00prin.pdf
It is a bit slow to open but seems to have plenty of technical info.
Good Answers: 181
10/12/2012 11:21 AM
Cheers Garth,
that should keep me quiet for a while. Unfortunately when we divorced my ex found all the vintage textbooks I'd acquired and sold them. How I miss them.
This should prove how good my memory is, or isn't and if I've got my drawing right.
10/13/2012 7:13 PM
Thanks, I sympathise,old text books are a valuable source of information, the internet does not have every thing available.
Register to Reply 10 comments
aurizon (1); Chankley (1); garth (3); Just an Engineer (1); NotUrOrdinaryJoe (1); TonyS (3)
