Previous in Forum: Differential Pressure Level Measurement   Next in Forum: RCCB/ELCB
Question Regarding Electrical Earthing
10/12/2012 8:42 PM
Dear all CR4 forummers,
wish you all can advise me. i had a situation at site, where there is an amount of earth leakage enough to trip my ELR at Distribution Board. this DB supply the power to my control power of MCC and Switchgear.
the strange part is, whenever i disconnect the protection relay earthing, things would be normal, no leakage occur.
what is actually the main problem behind this. what equipment cause this leakage. hope can advise.
tq
Good Answers: 34
Re: Question Regarding Electrical Earthing
10/13/2012 4:03 AM
There had been many threads in the past on ELR. Please "Search this Forum" on the right side of this page.
Good Answers: 181
10/13/2012 7:24 PM
Look here
Good Answers: 102
10/14/2012 2:01 AM
That doesn't mean that the leakage is not occurring it just means that you are no longer detecting it. ergo you have spragged the protection.
If your grounding system has been correctly designed and implemented and maintained you should be able to trace that leakage by a process of sectional disassociation and checking until the root cause is found and then take action.
Meanwhile continue production with trepidation.
10/14/2012 8:46 AM
GA
Well put.
The OP is simply dangerous and badly informed.
10/15/2012 9:30 PM
Firstly by disconnecting the earth You are creating a dangerous situation & risking the life of yourself & others in contact with the equipment. As previously stated by another member, disconnecting the earth does not remove the fault it only stops the ELR from detecting it. Any thing from the cable through to the equipment connected to the circuit could have the fault causing the ELR to trip.
MY advice would be to leave it all turned off, reconnect the earth & hire a qualified electrician to test the circuit & diagnose the fault.
Andy Germany (1); brettj1au (1); Joshi (1); TonyS (1); Wal (1)
