Re: Is It Possible to Make Unequal Multi Virator Outputs to Run a Motor?
10/14/2012 3:19 PM
Yes it is possible.
Try a simple internet search for the 555 timer as the datasheets available off the internet generally include application examples including using the 555 timer to power larger loads. You use the output of the 555 timer to power a transistor, MOSTET or relay coil which is then used to power the load.
