Previous in Forum: They Knew Who Won!   Next in Forum: Engineering News (In Lieu of Engineering News)
34 comments
Earth's Magnetic Frequency
10/17/2012 11:35 PM
Tesla was working on wireless power transmission when he died, and very little is known about the intended use of the towers with copper balls on top spaced at precise intervals.I read somewhere that he was intending to use the Earth's magnetic field to carry power by using it as a carrier.Can anyone tell me the frequency of the Earth's magnetic field?
Thanks in advance for any help.
Re: Earth's magnetic frequency
10/17/2012 11:43 PM
~10-15 Hz.
10/18/2012 7:04 PM
Has anyone tried to link the Earth's magnetic field frequency with our local electric power source - the Sun? In early 1900s Birkeland was working on the solar wind being electric current flowing into the poles. Took another 50 years before space probes proved he was on the right track.
Faraday demonstarted the homopolar motor and the principle runs spinning disk electricity meters today. I wonder what percentage of the Earth's motion depends on solar 'charged particles'. Can we detect the solar signature in the magnetic field?
What is that Cigarshaped object hanging in the sky ====>?
Good Answers: 1693
10/17/2012 11:44 PM
42
Canada - Member -  Member
Location: Hamburg NY (just south of buffalo) pre-Hamburg(1998) home was the Yukon territory of Canada
Good Answers: 27
10/19/2012 8:01 AM
I had to give you a GA! Adam's solution to everything.
Nothing is fool-proof to a talented fool
10/18/2012 2:57 AM
I think it changes every 200,000 -300,000 years or so.
10/18/2012 9:12 PM
Just found another link! Its an insider actually!
Seems Tesla will have to wait some 160-260 T years.
Good Answers: 50
10/18/2012 4:09 AM
The Earth's magnetic field really doesn't have a frequency. Years ago, some scientist recorded readings of the Earth's magnetic field and put it out as a stereo album. Its lack of frequency or its randomness made it sound like haunting music.
Re: Earth's Magnetic Frequency
10/18/2012 8:50 AM
Thanks for all the feedback.So how was Tesla going to use the Earth's magnetic field as a carrier?
The government must have been afraid he was on the right track,because they classified all of his papers pertaining to this project after he died.
Imagine pulling power from the air with a special antennae.
Good Answers: 444
10/18/2012 10:25 AM
We do it all the time, it's called radio, WiFi, radar, etc.
10/18/2012 9:16 PM
1. Its advanced technology that is not suitable for our society!
2. It mystifies Tesla so we can talk about it for years to come!
3. Maybe there is no real magnetic field and this is supposed to save keep the little men that move the compass needle. If so it was Gulliver who made the arrangements.
Did you really try to access the papers from Tesla or is it just web-chat?
10/18/2012 1:42 PM
It depends on how fast you fly though it...
It's not Rocket Science
Good Answers: 39
10/18/2012 10:50 PM
You should read up on HAARP in Wikipedia.
Align culture with nature...
10/19/2012 12:15 PM
the HAARP looks down at the moment however theres some past ACE/HAARP comparison
ci139
01/30/2013 1:20 AM
ci139
Good Answers: 59
10/18/2012 10:57 PM
You guys are funny. Still it ain't so. The Schumann resonances of the Earth start above 10Hz and goes up in some fashion to 50 or 60Hz. These are the "Hohlraumresonances" of a conductive ground surrounded by the conductive ionosphere. Tesla was having a respectable idea for the time. That, it was incomplete it led to its downfall. Never mind the fiscal problems.
Good Answers: 1693
10/19/2012 9:22 AM
Yes, and I read the value "42" directly from my LynDoor™Industries Precision Hohlraumresonanceometer.
Good Answers: 80
10/19/2012 10:27 AM
It is not because you can excite a resonance node that you can extract energy from it.
Resonance is a passive phenomenon. It doesn't produce energy.
Resonance is often used by perpetual motion promoters (scam artists) to show the over unity amplification of their devices. In reality, it is simply a form of energy storage that transforms the measured parameters through the intrinsic impedances.
In electricity, you can use a 1V, 1 A ac source coupled to an LC circuit and produce hundreds of volts and amps in the resonating circuit. The trick that is not revealed is that the phase between the volts and the current is ~90 degrees and therefore no (little) real power is flowing! Is is a "powerful" illusion when shown to most people.
Good Answers: 84
01/30/2013 2:44 AM
7.5, 15, 22.5 Hz and upwards at 7.5 Hz intervals, diminishing in amplitude with increasing frequency. I've measured them myself, and with relatively simple gear. These frequencies can also be derived from a purely theoretical standpoint when you model the system as a conductive, spherical annulus having the same dimensions.
10/19/2012 7:32 AM
@lyn...lmbo
Yep-stuck in the middle with you.
Good Answers: 54
10/19/2012 10:40 AM
What you are referring to is Tesla's "Magnifying Transformer". Look that up and You will find recent small scale experiments done here in California between UCSF and UCLA as well as experiments in Germany.
Essentially, it is a way of using resonance, and heterodyne with a base frequency equal or near the Earth's resonant frequency of 7.86Hz. Two identical coil setups are used in distant grounded locations. The idea is that the two coil systems form a long gap transformer linked through the electric potential at resonance and the ground current at resonance instead of the magnetic coupling typical of a transformer.
What is interesting about it is that when it is operating, that is both coils are tuned to each other and the Earth, then the signal from the transmitting coil arrives at the receiving coil with a gain in signal strength! This gain apparently comes from the potential in the field between the Earth and the Sun. If you read the transcripts of Tesla's speeches on the subject you can get a bit more of an idea of where he was going with it.
Google Magnifying Transformer and Magnifying Transmitter Reciever. Have fun!
10/22/2012 4:19 AM
Earth Magnetic Frequency is very high it can generate powerful energy.
Good Answers: 1693
10/22/2012 8:39 AM
Do you have something to offer to substantiate your outrageous claim?
01/30/2013 1:46 AM
http://en.wikipedia.org/wiki/Schumann_resonances
it should B that color however i have an order of 10 difference here 540e+12 × Phi-71 = 0.78391920111505875946670705600449
ci139
Good Answers: 84
01/30/2013 2:28 AM
7.5, 15, and 22.5 Hz are the first three of the so-called Schumann resonances of the Earth-ionosphere waveguide. Because the ionosphere contains charged particles, it behaves like a reflective conductor to radio waves whilst the Earth's surface behaves as a ground plane, causing the space between the two to act as a waveguide whose base resonant frequency is around 7.5 Hz - the first Schumann resonance. The higher Schumann resonances are harmonic multiples of this. It is not Earth's 'magnetic frequency' but the frequency of the Earth-ionosphere waveguide of which Tesla was speaking. The Earth's 'magnetic frequency,' on the other hand, is something altogether different: the rate at which field reversals occur, the period being every few thousand millennia or so.
02/01/2013 9:00 AM
i donno i trace the digit sequences
maybe'y've (the resonances) similar representation pattern in ten base no.sys
i just know that color is the "Earth" (((now i must remember in what connection - or it won't B of any scientific value ...)))
it set's it's refference source to Mediterranean-NW-Africa ???
& it clearly "states" it's of the inner-earth(mom.here) descriptor
??? plant's come from eatrh (?interesting typo) & 1-st get'hat paint
? they see the sun (mom (Fe+) there) so'ey must adopt to their role to keep in harmony with ???
??and 'ey say(lie/play) "we're not transparent(spirit) but neonYG" (central visible light spectra) (? we are the hart of you) ??? but the heartofsunFe+'s not YGneon ! but what the sun radiates (as life supportable) is . . . the light is "angels" passing through time witout remembering it . . . here-held spirits younger selves escape to no time stasis . . . (((i must narrow my "spectrum" pass or you wont get TSHOI XD)))
let's C the K words life support vis.spect.cntr sun.cntr earth.near_below_crust
?? "geo-thermal connction pt."
ok ... let's speculate the earth magneticF is important to plants (!) and it is - generates aparticle shield - so ◄ that leads us back to "spirit talks"
??"we are the life cntr of you" - so sun must "derive" the earth magnetic field in responce by adjusting "mom.here" (?? earth-termo cycle + notyetknown)
((& it has a meander resonance ((long waves = grandpa = crystals(also UV X-ray) )) )) ? whats the eart's Fe+ content near crust there are such as Fe-ic intrusions - the acidity of basalts is defined by 'eyr Fe+ content . . . other words whats the role of upper Earth in it's MF Formation - Integrity
. . . anyway you got what we seeking here (i quit'his'BSH)
ci139
02/01/2013 11:20 AM
One of the space shttles deployed a tether to see if useful energy could be captured from the Earth's magnetic field.To their surprise, the conductive tether snapped due to current overload.Much more power than anticipated.The next mission carried a heavier cable, and they were able to harness power from it.They discovered that when they drew power prom the tether, the shuttle slowed down, and when they pumped energy into the tether the shuttle sped up.
This could and probably is now being used to enable satellites to make corrections in their orbits without carrying a large fuel supply with them.Simply regulate the flow to or from the tether to change altitude.
Anyway, back to the main topic:
What if you could pull a conductor from beyond the ionosphere to the ground.Would there be current flow?How much?Unlimited perhaps?Is this what Tesla was attempting, or something related?Who knows what this genius was really thinking.He predicted and demonstrated radar,cautioned us about nuclear energy, built a remote control boat, and designed a totally automomous car, but couid not get funding.;described,robotics,cruise missiles.Some things he said that he saw were much to dangerous for man to posses at their current state of social development.
I realize the technology does not currently exist, but new nano materials may someday make a space elevator possible, so why not power cables passing through the ionosphere sending power up.or down the elevator ?The support structure could have more than one function.
Think about it with an open mind.
Good Answers: 84
02/01/2013 12:19 PM
HTRN writes: "One of the space shttles deployed a tether to see if useful energy could be captured from the Earth's magnetic field.To their surprise, the conductive tether snapped due to current overload.Much more power than anticipated.The next mission carried a heavier cable, and they were able to harness power from it.They discovered that when they drew power prom the tether, the shuttle slowed down, and when they pumped energy into the tether the shuttle sped up."
Link(s), please?
02/01/2013 5:36 PM
That was hard to do! I had to enter "Space shuttle tether" on Google.
https://www.google.com/search?q=shuttle+deploys+tether+wire&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a
02/03/2013 5:09 AM
the G2's (Earth) magnetic field frequency - may go to pre-u.s.1964 when the "Black op.-s" likely took place . . . . . . . . . i don't wanna think why'ey needed 4 (though they must've had technology to sh¡t around with - what we don't wanna know - such as a certain 11'5 by 10' coil configuration plate from Philadelphia Experiment blew blawh blaw wlelew)
ci139
02/03/2013 5:40 AM
why you neddit 4 - it would be much easier to get the right stuff if you point the brief. of your research
(running ahaead of that - let's see what you asked)
  • Tesla .... blah blah blah existed...
    he was intending
    power by using it as a carrier. echo echo
    Can anyone tell
    me the frequency
      • Can anyone tell
        me the frequency
the last 1's not a question
the last 1's a request for ("research continuation")
. . . you do realize that the G2MF to carry power must've some trick to "effortlessly" transfer it there . . . the destination has a direction . . . you don't want to spread it 3D - the frequency comes to play as "Quantum tele-portation" option - so if your src~dst @ same enclosed Q-state you might get some instant NRG-shift
there is a whole lot of science uncovered by now (this thread) to this
ci139
02/03/2013 5:48 AM
there likely is some similar phenomena in wave-phys. - speculating - the spiral wave (such as chem.-waves near your heart) tends to - self-encapsulate - at right conditions - there might be "phase difference" at center - there might be "mirror/quiet" state - there might be something as "µ-Level Dimension Drifter" due the relativistic times in different Fq.Phz. domainz - other words the wave might become imaginary or ...
ci139
02/03/2013 5:53 AM
... so the NRG is "packed" into """No-Time inside ""Time difference in "G2MF" "" """ , buff . . .
ci139
02/03/2013 6:14 AM
don't stear at me (not an 100Nswr machine - i just told what i know)
  • though it figures "THEY" knew smth. other than our now Phs.Txt.Bks tell us about EDBH ("the common people 2xstupid to handle 'eir S" - i gess there was such)
ci139
02/03/2013 6:23 AM
((((... such as the frequency is supertimeal phenomena that we precieve as something here . . . the time disturbance of whitch we - process out the - time-periodic series of sametime passthroughere . . . . . . . . . ""field"" . . . somewhat so))))
ci139
Register to Reply 34 comments
ben11c (1); ci139 (10); Cigarshaped (1); Deefburger (1); europium (3); HiTekRedNek (3); IdeaSmith (3); leveles (1); lonster (1); lyn (3); marcot (1); ormondotvos (1); RAMConsult (1); Rockyscience (1); SITMWY2 (1); Tornado (1); vermin (1)
