Previous in Forum: How to Calculate Vane Pump Pressure and Efficiency   Next in Forum: Powerpack Question
29 comments
Vapor Pressure of Natural Gas
11/12/2012 7:05 AM
What is the vapor pressure of liquefied natural gas at 70°F? At 120°F? Can an economic container be designed for these pressures?
A car operating on liquefied natural gas would have a lot more fuel storage for the same size storage container as compressed natural gas.
With the huge increase in natural gas supply, using it to operate automobiles seems the "natural" thing to do until we get an alternate to fossil fuels. However, the range of the automobile must be considered. Using LNG instead of CNG with the same size container would certainly increase the range.
Have some fun today,
PAPADOC
I'll live life my way until Willie sings.
Pathfinder Tags: CNG LNG natural gas vapor pressure
Re: Vapor Pressure of Natural Gas
11/12/2012 7:34 AM
Good Answers: 266
11/12/2012 7:57 AM
The container isn't the problem. The infrastructure needed to distribute it is what hinders it. Would be very costly.
Good Answers: 104
11/12/2012 8:48 AM
The critical temperature of methane is -117°F, so you can't have LNG at 70°F at any pressure.
11/12/2012 8:50 AM
GA
Good Answers: 1693
11/12/2012 9:48 AM
If it's good enough for PW, it's good enough for me.
11/12/2012 1:11 PM
What happens to the LNG when the temperature in the container gets above -117deg F ? If the container is 90% filled with LNG (leave a little void space) and the temperature goes to 100 degrees F, what happens? The amount of energy in the tank isn't going to change. So, if it's filled with LNG and it heats up to ambient. What would happen?
11/12/2012 1:19 PM
If the internal temperature goes to 100°F, the energy will change a lot, as will the pressure. If only the ambient goes to 100°F, the internal energy may change a bit from thermal leakage. LNG tanks are insulated and refrigerated (possibly self-refrigerated by bleed-off).
Good Answers: 104
11/12/2012 2:34 PM
At -117ºF, you'd already be at around 650 psi. (The normal boiling point is around -255ºF.) If you heated it to 100ºF, you'd be around 3500 psi. Don't even think about filling it at -255 and letting it heat up to 100ºF in a closed container.
11/13/2012 3:22 AM
Answer: it is no longer LNG; It's SNG [Supercritical Natural Gas].
In a road vehicle, volume is a constraint. So it makes more sense to use propane, which will have a liquid phase at ambient temperatures and more moderate pressures; the fuel tank volume contains more energy-of-combustion that way, and the concept vehicle would have a far greater range and weigh rather less than if methane/natural gas were the fuel.
11/12/2012 4:09 PM
Unless the container is cooled or extremely well insulated.
TT3
If the software can detect, compensate, avoid, or correct an anomalous condition in the system, it is, by definition, a software problem-regardless of the root cause. In the long run, for most classes of problems, it is cheaper to fix it in the SW
11/26/2012 7:19 AM
11/12/2012 10:04 AM
There are plenty of alternatives to fossil fuels. Very few want to use them.
11/12/2012 5:57 PM
Given the generalized specs for pure NG at the temps you stated its going to be in a physical state classified as a super fluid or dense gas. Ether way that will give it a static pressure of around 2000 - 2500 PSI in the 70 - 120 F temp range.
As far as containers go that the typical working range of standard high pressure gas cylinders used fore industrial gasses which are already mass produced and can be found in countless sizes and volumes.
Relating to filling such a cylinder with high pressure DNG (Dense state Natural Gas) its probably going to follow the similar filling rules of 80 - 90% NG volume measured by weight or specially designed and calibrated flow meters Vs the internal tank volume like how propane tanks are filled.
Personally as someone who has worked with propane and with high pressure cylinders plus the pressure regulators and related fuel systems for running vapor based fuels I don't really see an big problems with using DNG as a vehicle fuel.
Provided the enviro nutters don get their fingers in the design specs for the systems. If they do I would expect the safety protocols and requirements along with the systems themselves to be unnecessarily over designed 'for safety' of course and priced unrealistically high to the point of making the concept cost prohibitive to most anyone in the industrialized world.
Good Answers: 104
11/12/2012 6:30 PM
More like nitrogen, argon, etc. in a pressure bottle. One cylinder of methane at 3000 psi and 70 degF isn't going to get you very far. Not like propane - in a barbecue tank there is a distinct gas phase taking up ˜10% (when tank is 'full') over a distinct liquid phase taking up the balance. That's why when you shake the tank, you can feel the liquid swishing around. With supercritical fluids, there is no distinction between liquid and gas phases.
11/12/2012 7:28 PM
Read Kramarats link if you want to know more about what I am referring to.
Gases being held in their supercritical and dense phase while contained in tanks are not the same as just highly pressurized gases.
They get a little weird at certain temps and pressure points which can be greatly affected by the ratio of supercritical fluid to fixed tank volume due to not having specific phase change curve like propane which is why a specific filled mass to tank volume ratio needs to be followed for a specific peak tank temp.
Good Answers: 104
11/13/2012 9:44 PM
I went back and read it - that's interesting stuff for the blend that natural gas is, somemost of the components do have critical temperatures higher than ambient and the mixture behaves in a complex fashion. I was quoting properties of pure methane from a P-h diagram I had handy. And, actually, nitrogen, argon, etc. in cylinders are supercritical, just as pure methane would be.
11/14/2012 11:38 AM
They are classified as permanent gasses due to their natural tendencies to behave more like supercritical gases than supercritical fluids regardless of how much they are compressed even though they are past their critical point .
They are most often defined as super dense gases, permanent gases, or super critical gases being they still lack the necessary properties to be fully classified as being in a supercritical fluid state.
Mostly at this point how they are defined is more semantics than anything.
11/12/2012 11:51 PM
This is how they do it in China. Gas at atmospheric pressure. Economical container too.
11/13/2012 8:02 AM
OH that image invites so MANY comments: the dust and grime implies a semi-rural setting, the obvious local source for methane when livestock is around...
Good Answers: 458
11/13/2012 11:48 AM
Something about a gas bag immediately comes to mind
Good Answers: 104
11/13/2012 9:09 PM
Don't get too smug! The picture below, from this site, was taken around the mid-40's near Los Angeles . These gas holders were fairly common in earlier times. There was one at an industry near Houston when I lived there, but I'm not sure that it wasn't used for something besides natural gas.
http://blogdowntown.com/2006/11/2417-history-lesson-gas-holders
Canada - Member -  Member
Location: Hamburg NY (just south of buffalo) pre-Hamburg(1998) home was the Yukon territory of Canada
Good Answers: 27
11/13/2012 8:53 AM
there are already hd trucks on the road using LNG:
www.freightlinertrucks.com/trucks/alternative...trucks/natural-gas
Nothing is fool-proof to a talented fool
Good Answers: 458
11/13/2012 11:51 AM
Not LNG, CNG.
About the only type of conveyance using cryogenic fuels (and oxidizers) fly into space.
Good Answers: 27
11/13/2012 11:57 AM
LNG=Liquified Natural gas
CNG=Compressed Natural gas
We currently have a few LNG Plow trucks as well as a fleet of CNG vehicles.
Good Answers: 458
11/13/2012 12:21 PM
I'm good with the CNG but I am surprised to learn that trucks are using LNG due to the difficulty handling and storing cryogenic fuels. If you are constantly using the fuel, you of course can self cool it, but what happens when you shut down the engine?
11/13/2012 12:56 PM
CNG ≠ LNG ≠ LPG
Good Answers: 137
11/13/2012 3:53 PM
Following various comments about low critical temp of natural gas, use propane instead. That will liquefy by pressure alone at room temp.
11/13/2012 8:46 PM
http://www.energy.ca.gov/lng/faq.html
this might be helpful
Register to Reply 29 comments
Anonymous Poster (1); bigg (5); Brave Sir Robin (3); Codemaster (1); jmmyadam (1); kramarat (1); lonster (2); lyn (1); MkSteel (1); ozzb (1); PAPADOC (2); PWSlack (3); rickwil (1); tcmtech (3); Tornado (2); Turbotroll3 (1)
