Considering
A/the amount of light received from a light source decrease following the square of the distance. i/e a star located twice further is only seen with one fourth of the brightness of its closest equivalent.
B/the number of light sources (stars) increase following the square of the distance range you consider and star "density" is not decreasing as far as we can see in all direction.
then then sum of light coming from the stars of the whole universe should be infinite (number of sources compensing mathematicaly for the decrease of intensity) and make the nigh sky a bright continuous light source of infinite intensity, and therefor we should not exist at all to ask this question.
However WE EXIST (almost
) so we have an oportunity to answer this question.
Any answer not scientificaly sound is not valid here...but the bible was already giving an answer : see genesis...first day...
I would love to have ONE correct full answer covering any subsequent (implied) question....
