Hi folks, I want to know the difference between pressure and flow. I mean the relation. I recently had an installation on gas system. I used regulators to reduce my pressures from a high pressure station to a low station. In commissioning, my set pressures were okay but my flow was very low and could not light my burners after 30 seconds. Low flow droping the pressures. I want to know the relation between pressure and flow, and are there regulators that are meant to regulate flow as well as pressures? What might have been the cause of my low flow? I had enough gas in the vessel. Thank you.
