Ok, so the problem asks for the voltage across the capacitor (which I found) as well as the voltage across the resistor which I'm unable to figure out. Any help would be greatly appreciated.
Problem: Find the v(t) and Vr(t) for t>0. The initial circuit has been in the first position for a long time until it has been switched over.
I got the initial voltage of the capacitor which is (8v), and I solved a second order to find the complete equation for v(t), but I don't know how to find V across the resistor. I attached my steps for what I did so far.
Attachment is pdf, so going to try that as its easiest for me to do...
So can I find Vr using the same method as I did for the Vc? Or?
