Previous in Forum: Rotor Earth Fault Protection Alternative   Next in Forum: Pure SINEWAVE Output from D/G !!
25 comments
Why Electrical Motor Using Terminal Block?
02/08/2013 3:42 AM
Hello, I have 55kW TECO electric motor but no terminal block.
My senior engineer said it okay without terminal block, we just connect it using bolt and then tape it using insulation tape.
But for me, it is very important for maintenance and safety.
He said big motor dont use terminal block, only small motor use it.
Re: Why Electrical Motor Using Terminal Block?
02/08/2013 5:48 AM
you could double check with these guys here!
http://www.teco.com.au/home
02/08/2013 6:03 AM
We have a couple of big motors connected this way, but we do not use normal electrical tape to wrap connections, it is 3M high voltage tape.
02/08/2013 6:11 AM
There may be a reason he is the senior engineer.
02/08/2013 11:05 PM
Yes, he is older than me :)
Good Answers: 266
02/08/2013 7:52 AM
Your reference to small motors have terminal blocks. I find that not true. Most terminal blocks will be found in definite purpose motors. That is is how the OEM that uses them spec them out.
Most just have leads as you show them.
Those bolted connections we wrap them with a rubber splicing tape first. To form a tight ball before wrapping with electrical tape. This is to keep any sharp edges from cutting through the electrical tape due to vibration.
02/08/2013 11:06 PM
That is why I ask why some motor have terminal block while other don't. What is the purpose ?
02/08/2013 11:38 PM
For DOL or 3 terminal motors nowadays some use 3pole+E plug and socket fitted on the terminal box.
I am not sure whether they are doing same for star-delta(six terminal) motors.
pnaban
02/12/2013 10:53 AM
Refer www.meltric.com/index-ecm for 200A 4P plug and socket for motor terminal box
pnaban
Good Answers: 117
02/09/2013 12:48 AM
while your concern for safety should have been acknowledged... (did you tell your boss before you wrote in this forum?) and can only be commended.... there is the old Army saying... "Follow the last order"
As he is your boss, and I guess that you are not the Senior Engineer yet, you should ask the question at the time, BUT follow the last instruction, as he is the responsible person and if it goes 'pear shaped' it's on his head!
If it does go belly up then you can say.... Nothing! After all he is the boss and will not take kindly to being told he screwed it up.
But, I don't think he got to his position by mistake.. so have you thought he might have something to teach you?
02/09/2013 2:23 AM
Hello, On my experience I have never seen electrical motors without terminal block. No matter how many KW is. For having terminal blocks on the motor, there is some conditions. 1) Easy to connect and disconnect power supply. 2) Easy to change over from delta to star or vice versa. 3) More safer compare to connect by bolt and isolate by insulation tape. I do that way when the terminal block is broken and I have no choose. Regards,
02/09/2013 4:59 AM
dear engineer
you will not connect terminal as attached photo, where is supply, you will either connect to star delta or soft starter or vsd , so you will find terminal as it delivered
regards
02/09/2013 7:09 AM
All the large motors I've done were just like that.Some 12 leads 9 or 6,Generators are similar.Looks like yours is a 6 lead 3phase vertical pump application?.Just be careful about how your connected.Ask your boss if it is "across the line start&run" or is it "Wye start Delta run" and tell him that "I don't assume anything with electrical!".Just do what the chief wants and you can't be wrong,LOL,well 99.9% of the time.Hey it's his baby!
"Hope for the best,expect the worse,and take whatever comes!"
02/09/2013 7:53 AM
So, did anyone ever use TECO motor? Is this their standard?? Because ABB motor have terminal block. I haven't mention that this is new motor.
02/09/2013 8:30 AM
I found in the internet about TECO. This is Chinese maker am I wright?. In this case I am shore it's violation from the maker. I can say why mostly makers using Terminal blocks. Respectable makers are like: ABB, Siemens etc. never sells the motor without terminal block. There is one important think regarding terminal block. Once you secure the wires by bolts and isolate by insulation tape, but after some time because of heat the tape can be opened and wires will be naked and you can get short circuit or earth leakage.
02/09/2013 4:22 PM
TECO is TAIWAN Electric Company. Chinese, Yes. Mainland, NO
02/09/2013 10:08 AM
All motors have terminal blocks for anchoring the terminals in a place. Some times the terminal blocks get burnt due to loose connections, flash over etc. In the absence of a spare terminal block( it is normal not to stock terminal blocks), as a stop gap arrangement the motor terminals are directly connected to the supply cable with nut bolts. Usually the terminal blocks are replaced at the first opportunity. If the person responsible does no do it, then at a later date some other person may conclude that the motor was supplied without terminal blocks. Best thing is to buy a new terminal block and fix it.
02/09/2013 2:16 PM
Terminal Blocks cost money. If the motor was supplied without it, then it is for economical reasons only.
If the maker is far eastern, they need to be told specifically about the standard you want. They are very good at short cutting specs.
In any case, the motor will work fine if properly joined. The inconvenience is for the maintenance periods hwere you might want to isolate the motor at the terminal box.
Good Answers: 42
02/09/2013 4:13 PM
What you show is typical North American. (I used to work for at a large AC motor manufacturing plant). Bus bar connection usually also required an over size conduit box. What you get is usually what you specify. The joints you have are usually bolted, then wrapped with a rubber tape or cambric to form a smooth ball around the parts, then wrapped with electrical tape.
It is a real bother if the rotation is wrong, everything has to be cut open again.
Bus Bar does increase the risk of arc flash exposure to the electrician working on an open junction box.
02/10/2013 9:00 AM
Hmm, I'm a bit confused about this matter. Some expert said okay without terminal some said not okay.
02/10/2013 4:43 PM
ive been thru that situation as well just follow the simple rule
1. the boss is always right
2. if the boss is wrong, see rule no 1
either a budget constraint or non standard issue but if the workmaship and insulation test is ok the nothing to worry
Good Answers: 42
02/10/2013 6:05 PM
I do not think it is so much OK or not OK, but that either solution is OK when assembled properly. I have seen far more motors without terminal blocks. In large motors, 300HP and up, I usually see either connections like yours, or the customer specifies bus bar, and usually specifies the number of places for connecting parallel conductors. When you get 3 to 6 parallel conductors for 1000Amps or more then the whole junction box and cable layout becomes very important.
With smaller motors like yours, in North America what you have is typical. You will have a small number of conductors of light weight that are easy to bend and you can stuff the connections into a small connection box. With Terminal boards you need a larger box for mounting the TB's, and allowing for more room for proper exit from the TB to the conduit entry. This has additional cost and room for very little benefit.
I know that different industries usually have de-facto standards that are not mandated by code. It is just a custom, and as a supplier or specifying engineer if you can identify these nuances you have a better chance with that market.
02/10/2013 9:53 AM
terminal blocks are also costly.
12/13/2024 8:48 AM
What is the <...cost...> of NOT using them?
02/11/2013 12:06 PM
See the listing details, if this motor is approved and listed by National Recognized lab. Noramally listing will indicate connection details.
07/11/2018 12:29 AM
Terminal Blocks are very important w.r.t. to following reasons:
  1. Easy to Connect and disconnect with proper torque which is not possible in suspended type lug-lug bolted connection.
  2. Maintains mechanical clearances between phases in all conditions
  3. During short circuit inside motor, it holds the terminal leads in place & absorbs electrodynamic forces generated on terminal leads which otherwise can swing the leads and in severe cases can damage the Junction Box.
Register to Reply 25 comments
Balbir Salwan (1); brich (1); febriansasi (4); GW (2); IdeaSmith (1); JPool (1); LAA_Lucke (1); msjaved (1); ozzb (1); Phil D. (1); pillay (1); pnaban (2); Priyadarshan (1); PWSlack (1); skipperj (1); tarekzeftawy (1); Tornado (1); totolas (1); Vugarich (2)
