Hi? I'm working in the plant construction project.
During the motor inspection for Process Pumps in workshop today and discovered that three out of eight of inboard/outboard oil-seals were missing at motors lubricated with oil mist system. (FYI, some grease was coming out when the motor solo run test was carried out and then the oil mist system was polluted by the greases.) This is very serious issue which affect the life cycle/ integrity of the motor. Many motors of several types were already installed. And the plant commissioning is planned to start soon. However due to some motors having the problems, it is directly impacted on our plant commissioning schedule and this will cause the enormous cost impact. In order to avoid the worst scenario that all installed motors shall be dismantled and moved to workshop to check inside motor, I would like to ask you to advise how to confirm the existence of greases and oil seal inside motor without any dismantles of motor in detail. (eg, using nondestructive test device...)
