Dear Friends and Associates,
I am designing a product for a client for consumer installation. It requires the consumer screw it to the wall.
It is not massive,but only about 4 pounds. Generally it will be hung between eye-level and waist-high.
Because it is attached by the consumer, I am trying to determine the correct number of screws to use, assuming the worst case of installing on drywall and not hitting any studs, but relying only on the strength of the drywall. Minimum standard in the States is 1/2-inch. I would suggest to the company to include both small lags for studs, and screws with expanding plastic inserts for plain drywall.
At a minimum, I will design the product for 2-screws because it being level is important, but any number of screws (within reason) is possible.
I have some some searches, but so far only found blogs where there were LOTS of opinions ... no real data. My plan is, if I can find a bona fide guide, I will increase by at least 1 screw for safety.
Even then, as with all consumer installations, one cannot be assured of a proper installation, but I want to at least design the product correctly, and provide proper instructions.
Any help or guidance is appreciated.
Kind regards ...
