Previous in Forum: Electrical Short Circuit Test in Transformer   Next in Forum: MCB. Knob Spring Grade
12 comments
Practical Use by Electrician of RMS Meter.
04/05/2013 6:29 AM
I know this is basic and I have tried to google to no avail.
What in actual real life do electricians use true RMS meters for? Are decisions about gauge of cable/fuses used based on use of true RMS meter? What else, if anything?
Re: Practical use by electrician of RMS meter.
04/05/2013 7:13 AM
RMS meters are used for accurate power measurements. They are not used for sizing cables/fuses, which instead are sized according to electrical code rules.
04/05/2013 3:25 PM
Thanks thats helpful and I do appreciate your input. To be honest the form of answer I am seeking goes like this "The most common time an electrician will utilise their meters RMS capability is when..........such and such........ and then the electrician will do..... such and such.... in response to their meter reading.
Re: Practical Use by Electrician of RMS Meter.
04/05/2013 3:05 PM
Tank Circuit
You seem to be confused regarding your understanding of meters. Tell us where you received this information so you can get the right information. True RMS meters are used for more accurate measurements when harmonics are involved. Average reading meter will not give an accurate reading under these conditions. However, most electricians are not called upon to make these type readings. Consider electricians that only work on residential or small commercial projects.
http://www.escoglobal.com/resources/pdf/white-papers/True_G2.pdf
04/05/2013 3:50 PM
So are you saying that an electrician working with something like a Phase Cutting Speed Control or other industrial gear will need to use RMS meters, but electricians that work on residential property will hardly ever/never use a meters RMS ability and could just as well own an average responding meter?
Thankyou for your input.
04/05/2013 11:00 PM
I'd give that a yes.
But, back up a bit. Non TRMS meters are usually average responding, RMS reading and assume the input is a sine wave.
Estimating power from a phase angle fired SCR to a resistive load would require an TRMS meter. So would the current from a PC switchmode power supply and a florescent ballast or anytime harmonics are present.
Remember TRMS is basically the equivalent value of DC that would produce the same power.
Good Answers: 27
04/06/2013 7:28 AM
Most RMS meters are actually peak responding, rms reading to account for variation in periodical waveshapes.
Good Answers: 82
04/06/2013 1:23 PM
Yes, "rms meters" may be and probably usually are meade with a peak responding rectifier, as you say, but "true rms meters"are another matter entirely, with a little RMS calculating machine: square the signal, average this and perform a square root on the average. Most meters use one of the high-speed AD536A or the cheaper AD636, AD637 or AD737 chips from Analog Devices. These perform the transfer function Vout = (avg Vin2)½, to an accuracy of 0.2% to 1% (max) of the reading, depending on the part you choose.
The scheme in the original Analog Devices design, shown in the AD636 drawing, was to first take the absolute value of the signal, then twice the log of the signal (two transistors in series in the feedback loop), create a current proportional to this, average the current with a capacitor, and place it in a square-rooting feedback loop. As a bonus in this circuit, you also get a logarithmic dB output.
The small 8-pin AD737 chip is probably what you find in most handheld true-rms meters. It's a low-current part (5V, 130uA), featuring a power-down mode, selling for $7 at DigiKey. It's clever circuitry performs the same functions as the schematic above, but with a different transistor layout, see Figure 1 in the datasheet.
Analog Devices has application notes explaining the use of this technology. There is some competition for the Analog Devices chips, Linear Technology offers the LTC1968, also available at DigiKey. This chip uses a delta-sigma computation method.
Thanks, Win
Good Answers: 12
04/06/2013 3:24 AM
An averaging meter and a true RMS meter will read the same when measuring a sine wave. A true RMS meter is required when the ac is not sinusoidal.
Good Answers: 27
04/06/2013 7:48 AM
RMS or Effective power measuring meters are use for more in-depth, critical circuit analysis, as to (the actual efficiency of the system). To determine how much real power had been effectively consumed or used and therefore the equivalent rate, how much money will be coming out of your pocket!
vsar
04/06/2013 11:58 AM
Power in places with heavy loads will have a flattened sine wave. An average responding meter will read in error in such a case where a TRMS meter will read accurately. Use of an oscilloscope will show if there is significant flattening.
04/08/2013 3:57 AM
Did you really do a google search?
http://en.wikipedia.org/wiki/True_RMS_converter
04/10/2013 7:53 AM
Yes I did. Whats interesting is that many people have responded to this thread by answering the question "What is an RMS meter and how does it differ from an the basic sort?" but that was not the question.
Register to Reply 12 comments
Bluestone (1); Dodgy Solenoid (1); KeepItSimpleStupid (1); Snave (1); StandardsGuy (1); Tank Circuit (3); Tornado (1); vsar (1); wareagle (1); Winfield Hill (1)
