Previous in Forum: Houses With A False Front   Next in Forum: Prefab Hospital
19 comments
Siphoning Water Through a 24" Pipe
04/24/2013 12:36 PM
I have about 3,000 acres in Louisiana; marsh land with levees close to the gulf of Mexico/tides. I have culverts w/flap gates installed to move water; this is dependent on the tides. During extreme weather conditions (heavy rains/hurricanes), I can't remove the water fast enough. I am comparing the cost of additional culverts w/flap gates (about $4,000/structure) versus siphoning the water. This is a large scale; looking at 24 inch culverts/tubing crossing over a levee that is 3 feet above the water line and 20 ft wide - differential in water from inside to outside can be anywhere from parity to 2 feet. Is a siphon of this magnitude possible and if so do you have any idea as to the cost?
Pathfinder Tags: siphon
Good Answers: 1693
Re: Siphoning Water Through a 24" Pipe
04/24/2013 1:50 PM
There's a siphon big enough to drive a truck through 20 miles from my house in Arizona. It carries water in the Central Arizona Project.
As long as the level of the outlet stays below the surface level of the water being siphoned, it should work.
How expensive? No clue.
04/24/2013 10:40 PM
Agree with Lyn
Automatize it -- time with low tide .
Fill the Syphon from an overhead reservoir or using a small pump.And have a compressed air tank to operate the valve .
Automatize to open the motorized Flap/Butterfly valve WHEN down stream level is low enough.
It is only a 24"pipe and air operated full bore Butterfly valve.
Most effective - yet lowest cost-and fastest drainage OUT
04/24/2013 2:44 PM
I think you may run into some issues with priming a pipe that size and getting it to stay primed for such a small elevation change.
Personally if I was dealing with a 0 - 2 foot or thereabouts difference I would just go standard culvert and flap gate route. It may cost a bit more but you don't have to fight with setup priming and whatnot every time you use it.
Good Answers: 58
04/24/2013 7:16 PM
I just siphoned the pool out. Luckily it's on a hill. Every time it rained, I had to do it again, to keep water off the cover. I thought about an automatic siphon. As far as I know, the inlet pipe curves as low as possible, and then up, below the desired level. Then it goes up and over the dam. The exit has to be below the inlet, but curve up to maintain a full siphon tube. When the level goes above the top of the exit, which is the desired level in the target area, siphon is started, automatically. As long as the level in the inlet is above it's top, the siphon should drain the area.
Otherwise, getting a siphon this big started would be a bear, I imagine.
I saw a device like this in a fish tank. It maintained a level in the tank which was receiving salt water from the river. An overflow would have allowed fish and stuff to get out of the tank.
mike k
04/24/2013 11:02 PM
A siphon will not work if the levels are at parity of course. But if there is a reasonable differential, a siphon will work without the need for valves. If both ends of it are under water, you can start the siphon by applying a vacuum to the highest point in the system. The siphon will start when most of the air in the pipe has been sucked out. Farmers in the San Joaquin delta area in CA use this method for irrigating many thousands of acres.
04/24/2013 11:54 PM
If the priming is done properly so that there is no air entrapped in the pipe, any amount fo water can be taken out. May be some way to keep the pipe always flooded will ensure that siphon works. As long as outout pipe level is below the inlet pipe, it works
Best Regards, Shivaram
Good Answers: 117
04/25/2013 12:13 AM
The nice thing about a siphon is that you can scale it up or down with little problem. The difficulty is the re-priming. A lot of water can be moved with several smaller, more easily primed siphon tubes, as this photo demonstrates. And you can use a automatic priming siphon for the purpose... but the auto prime device may cost as much as the flap valves you are trying to replace.
Because you are dealing with tidal conditions, rather than the Murray River/ Lake Bonney levels which pretty much stay constant, you need an inverted siphon to handle your variable flows.
All you need is a ball in a cage on the outlet side to prevent back flow, and bob's your uncle.
Do flapper valves on culverts REALLY cost four grand a pop? Wow!
Oh, and we had a nice discussion about reverse siphons here.
04/25/2013 9:10 AM
I installed a venture type educator on the exhaust of our Alice 140 and used this to start a siphon for draining a lake to do bottom work. We were using a 12" pipe and I plugged the lower end until the pipe was full. Knocking out the plug was easy once the valve was closed at the top of the siphon with it full of water. I was not prepared for the force of the water coming out of the pipe. Got wet and muddy before getting out of the flow. This is a simple educator set up that can usually be found on field pumps used for irrigation. Moves a lot of air from the pipe and when the water starts spraying close the ball valve at the siphon high spot and the water will start moving. If both ends are submerged in water covering the ends you do not need to plug the pipe. These were also used on portable pumps we used on ships to assist with dewatering or fire fighting.
Anything can be made, sometimes at great expense, resulting in greater satisfaction, :)
04/25/2013 1:57 PM
The pipe that is utilized for a siphon should be chosen on the basis of its ability to withstand negative pressures and not letting air leak in.
04/25/2013 6:17 PM
You might like to consider an "inverted syphon" instead. No difficulty in priming and you can have the opening triggered by a float attached to the seal on the inlet side.
How many culverts/flaps do you already have? What is the fall to them?
You may be limited in water removal purely by the ability of the water to cross flow the fields.
(Note that an inverted syphon could be located further into the paddock and thus provide greater avacuation potential.)
04/25/2013 6:54 PM
With the drop you have and the gauge of the pipe, I would assume a Vortex would be created causing air to intake and stop your siphon.
Maybe multiple smaller pipes would be a better idea? Start one of the smaller pipes off with a small jacking pump, run a small feeder to the second and so on until all pipes are primed and siphoning.
Cheers Glenn
Have you tried turning it off and on?
Good Answers: 1693
04/25/2013 7:01 PM
How many of these:
  1. Aluminum Siphon Tubes - Empire Irrigation Product Lines
  2. plastic irrigation siphon tubes available shapes and sizes ...
equal a 24" pipe. Plastic ones would be easy to cut and stretch.
Good Answers: 179
04/27/2013 10:49 PM
Whatever you do, DO NOT excavate through that levee....don't breathe on it, do pee on it, and don't spit on it! LOL Seriously, breaching it will bring the US Army Corps of Engineers to your drop step in a hurry, and they will be extremely displeased with you. And most likely you will be fined very heavily and held liable for any and all reconstruction repair costs!!!!
Go with an inverted siphon only if you can avoid the above.
Signed,
the Capt. (who formerly served at the USACE NO District Offices).
Good Answers: 117
05/13/2013 10:36 AM
Good point. More than good point....grin! There might be other considerations...like, Some levees are designed to have a roadway on top of them, and a siphon might be considered to be a road hazard.
I assumed that if he has permission to install a check valved culvert, then why not an inverted siphon? Is this whole exercise an attempt to get around a standard installation which is, once in a while, not quite good enough? I will assume this is the case. In which case, a standard siphon would keep him out of trouble.
Do you suppose that if the siphon was to be inserted into shallow sumps on both sides of the levee, it would eliminate the problem of loss of prime every time the tide went out?
A sump on the outflow side would allow room to install a simple check valve to eliminate the backwash the levee was built to prevent....
I like the idea of an "automatic siphon...but at some point, the water level must rise higher than the highest point of the bend for those to work...and that is not going to happen in THIS application.
Good Answers: 22
04/28/2013 7:49 PM
Something which may help...
I remember seeing a demonstration as a young man which I believe could be relevant.
A local water utility was looking into a stormwater drain overflowing during heavy rains. It flowed through a large culvert and the water backed up when it hit the side of the culvert and caused it to overflow causing the localised flooding. The sides of the culvert caused the water to create eddies which interrupted the flow into the culvert pipe (a large pie approx 4ft dia?).
They did some modelling to investigate possible solutions. They built a scale model & tried several options which they showed us with actual water flow.
They put in a second pipe (i.e. 2 pipes of the same size), they tried a much larger single pipe, but the other thing they tried, and which was successful, was to streamline the approaches to the existing pipe. This eliminated the turbulence caused by the water when it hit the surrounding flat vertical surfaces around the opening of the culvert pipe, and assisted the water to increase in velocity as it approached the pipe & thus increased the flow capacity. This was the successful solution.
They were able to achieve a higher flow rate simply by streamlining the approaches to the culvert pipe, and it flowed better that 2 pipes or a significantly larger one.
Hope this helps.
04/28/2013 9:31 PM
What "OLDTECHNEWTOYS" saw 50-60 years back was demonstration of just that : Streamlines Venturi effect in an open channel-
OP's problem is different; Of Time and Tide and Costs
Siphon is The Answer-- with automated discharge valve+land side flap check valve .
"Old Tech New Toys " indeed .
As old as Roman aqueducts
Good Answers: 22
04/28/2013 9:49 PM
"50-60 years back"... How old do you think I am??? Only 56 yrs young!
re your comment - "OP's problem is different; Of Time and Tide and Costs".
I would respectfully dissagree...
QuentinGreen states - "During extreme weather conditions (heavy rains/hurricanes), I can't remove the water fast enough. I am comparing the cost of additional culverts w/flap gates (about $4,000/structure) versus siphoning the water."
So he is considering additional culverts, which is exactly what one of the options was in my example.
I see his post as saying that if he can remove the excess water fast enough (say, by inrcreasing flow in existing culverts) then additional culverts or the siphoning option may not be required.
06/11/2013 9:41 AM
" WWW.AZEEMO.COM " I think this will be helpful website for engineering undergraduates.
It has complete engineering projects for all departments & has both free & priced projects with low prices.
Hope you enjoy it.
09/24/2024 7:12 AM
<...have any idea as to the cost?...>
There are commercial considerations, which will be facility-specific and commercially sensitive information. It is unlikely to be able to find meaningful information in a global engineering forum such as CR4.
Register to Reply 19 comments
bht2010 (1); CaptMoosie (1); ccoop610 (1); eng.proje (1); Just an Engineer (1); lyn (2); mike k (1); MUKULMAHANT (2); OldTechNewToys (2); Oraka (1); PWSlack (1); RicinCinci (1); shivaganti (1); tcmtech (1); Yusef1 (2)
