Previous in Forum: Smart As a Dandelion   Next in Forum: Cast-Away
73 comments
Why Would You Want a Lathe to Run Backwards?
04/25/2013 3:23 AM
I managed to blunt a tool before I reaized the lathe was running backwards.
After a while I located a switch which made the motor start up running t'other way.
I never did finish the job, I think I work hardened the steel and ruined the tool...
I'm a baaaad kitty
But why was the switch even there?
It's Dad's lathe. He's well into his 80s now and his workshop is falling into a sad state. Tools all over the place, oil spilled on the bench.
(My brother is going to clean up a bit and get the lathe cleaned up as he can use it occasionally)
Re: Why would you want a Lathe to run backwards??
04/25/2013 4:30 AM
Is it so the thing can be used in the Southern hemisphere as well ?
I dunno, but it sounds like a highly dangerous system. Which side of the lathe were you standing on ?
Sounds like your bro is a good sort, but he might not like you mentioning his personal hygiene . My own siblings would stand about laughing.
No mention of what make/model of lathe ? As ever, I'm posting on something I know nothing about (well, CR4 would hardly be interesting if I couldn't read up on such). My dad had a lathe of some sort, but when he died it wasn't really practical to get it shipped here from Milton Keynes.
Good Answers: 141
04/25/2013 4:34 AM
Hi Dell,
All Lathes (except some for wood) are supposed to run in 2 directions. You need this to cut thread with profile knives. Or also for upside down work.
Plenty of room here
04/26/2013 6:16 AM
dvmdsc, in BAhamas
Thanks for answer. I undwerstand the part about threading, but do exmplain what upside down work is.
"Keep on keeping on"
Good Answers: 141
04/26/2013 10:53 AM
Most lathe men work with the mandrin or shaft spinning towards them. Workpiece spins counter clockwise (view from the end of the machine). Knife tool is centered a little bit
"under" the center. Depending on speed, pass taken and nature of the work piece, the lathe reaction is to lift the shaft up to the bearing play. This causes jitter and vibrations and you see and measure that in the end product. When you work with hard steel bits, they can even crack and diamond knives lose their diamonds this way.
By letting the lathe turn the opposite way - clockwise - and installing your knife point a bit higher than the center, the reaction of the lathe is to reduce the bearings play to almost zero. The knife has to be upside down for this cutting.
Safer for the operator also, but less view on the work. A relatively worn out lathe can work with a far better precision.
And some new ones get 0,005-0,001 mm as tolerance used this way. These are about milling machine tolerances. But keep it between us.
Plenty of room here
04/26/2013 9:17 AM
GA.
I'm surprised that I was the first though.....
04/25/2013 4:42 AM
Surely you can put it into reverse in case you take a little too much off the work piece.
So: a brother, I always wondered if you had siblings called Ctrl and Alt.
Running a lathe in reverse.
04/25/2013 4:46 AM
<groan>
04/25/2013 5:00 AM
'Ctrl the cat' and 'Alt the cat'? That sounds a bit unlikely...
04/25/2013 5:08 AM
Ain't nuthin' that can't be googled now......
I've said it before (OK, I pinched it from that Carr bloke)...the solution is Smarties tubes on the legs. Instant robocat !
04/25/2013 4:48 AM
Hey dude... linking the Cat to a google search is takin' the mick.
I shall go sulk in my cat nest now
(Actually some good answers there.... ta' )
04/25/2013 5:03 AM
Feel free to give me one (so to speak) - my GA/post ratio is looking rather sad.
04/25/2013 5:15 AM
The off-topic/post ratio is looking rather good, though.
04/25/2013 5:48 AM
...and do you recall who/where holds the record for most OT votes on a single post ?
If you knoe the OT record, then let me know - it was an alltime CR4 funny. I forget why, but everybody hit poor Del with an OT.
Another classic was somebody posting the same thing twice, albeit a few years apart.
GA's is easy - just jump on a new post and give some decent info. There is a distinct voting bias towards the earliest post. By way of example, look at how the voting goes on Challenge questions - people tend to read the first few posts and vote accordingly. Their is also a tendency for people to click on first GA, then add to it if it seems good. Post something good at about #30 and most people will miss it. Bitter, moi ?
04/25/2013 5:58 AM
Once upon a time, moderator Merph gave someone several thousand OTs as a joke. I've forgotten whom.
04/25/2013 6:34 AM
That's a name I don't know (but will certainly look into now). Mizuti has pulled some funny ones of a similar nature. It makes a huge difference to have moderators who have a sense of humour, and CR4 has some of the best I've seen on any forum. The majority of places I visit are very dry and starchy - CR4's moderators get involved and keep the whole atmosphere the fun way it is. Moderation where due, but also diving into the fun. They all seem to strike they right blance.
This post has absolutely nothing to do with the soon to be proposed ' let's reward our long term members who are committed CR4 fans and help to keep the forum the unique way it is' . Besides, It would be wrong of me to try stitch up people like yourself, Del, Lyn, Doorman....<endless list>
Register to Reply Off Topic (Score 43)
04/25/2013 3:09 PM
Who dares wake me from my slumber?!
The first law of thermodynamics is you do NOT talk about thermodynamics.
04/27/2013 2:58 AM
As if you'ld chance sleeping whilst Del had a 'live' thread going
In reply to #63
04/27/2013 3:25 AM
Too right... I nearly ranted at Solararts #49.
I even wrote a scathing retort twice but didn't post 'cos he's fundamentally right.
Not sure he could have been any more patronising tho' ?
The rest of you guys know by now that I'm not a complete twonk (mind there are courses I could go on to gain completeness.... 'philosphy of marketing' or 'Economics Theory' spring to mind).
I quit every time I knew it wasn't cutting right and found the trouble or stopped entirely. I didn't think 'wow maybe if I try a 1/4" cut.
Maybe he should check out some of the stuff I've made?
If ever he posts a bow making Q... will I tell him to go on a course?
(There, I got the rant in eventually)
In reply to #64
04/27/2013 6:24 AM
'attaboy - let it out !
It's OK, folk who've been here a while know how you have tried so hard over the years to master some basic skills. Countless blathering posts, and yet we still try to nurture you along in the basic skills.
I'll have to read it again, but maybe there is some valid point in Solararts post and it was just worded 'wrongly'. No worries - we all probably feel on the recieving end of such at times. Mrs K still nags me about the quality of my washing-up the dishes - a tad unfair, because I always try avoid doing it so what's to complain about .
mis-comm's, or a bit of baiting. Not worth a second though old chap. Some pilchard just hammered on my door, garnering votes for the local elections. Did I tell him to ****-** etc, etc. erm....no, bad example. The dog thought he knew best which direction he wanted to go for his morning walk....agh,,,,forget it.
Good Answers: 295
04/25/2013 9:20 AM
"...and do you recall who/where holds the record for most OT votes on a single post?"
Doorman got himself quite a few OT marks on this one.
04/25/2013 12:57 PM
Unfortunately someone else has added another off topic. Someone here has to go and vote it on topic so that the off topic score matches the date again: 11 10 2010
I used up my vote when someone did it before.
I wonder why I care?
04/25/2013 1:14 PM
How do you get 11 million+ OT votes?
There aren't that many members on this forum!
Good Answers: 295
04/25/2013 1:28 PM
"How do you get 11 million+ OT votes?"
Like I said in the other thread, I REALLY torqued that guy off!
I'm not just a Jerk, I'm a Jerk Doorman!
04/25/2013 1:50 PM
Obama's Voters and tweet followers had a slow day.
04/27/2013 2:52 AM
classic......the hand/paw of Mizuti strikes again !
04/26/2013 10:57 AM
I am amused by some of the posts here.
Running the lathe backwards ... reversing the metal removal process, when you have cut too deeply. I have thought of that, but never did get it to work out for me. I do not have one of those metal-applying tools, plus you could cut your fingers, while feeding that curly strip of metal.
The photo posted of the wood lathe is incorrect. Its frame and supports are clearly steel, not wood. Anyway a wood lathe is a bad idea, the material is not strong enough, and swells in moist weather. Would it have warp-drive for humid summer days?
Same for a glass lathe... would it not crack if bumped? Does a glassblower, rolling his blowing pipe on his bench, as he smooths the hot work, consitute 'lathe turning of glass'?
Seriously, I find that reverse is best for cutting the inside of a surface. I like to look at the tool, and if it is inside a piece, reverse makes this simple. If I need to polish an item, I prefer to use reverse. My 8" chuck is attached by a simple right-hand thread, but I make it tight enough that it never comes loose in use.
David
Isn't the french fry the most COMMENTATOR ?
Good Answers: 119
04/26/2013 11:10 AM
I always hated, when I needed to reduce the diameter of a blown cylinder, sucking on the pipette attached to the rotary coupling. The heat and gases inhaled ruined the taste of cigarettes for weeks.
Hooker
04/26/2013 11:08 AM
You are not far wrong. In my apprentiship I was shown how to add material if the bearing fit I had just turned was a bit loose. You just put a few thou cut on the tool and ran the lathe backwards and as if by magic the bearing fit was tight.
Good Answers: 918
04/25/2013 7:29 AM
"Why would you want a Lathe to run backwards??"
Threading!
I use this all the time for taping and threading. I routinely run taps in and out with my lathe. You need reverse to do that.
Tool blades are cheap and you can anneal hardened steel or have someone with a torch or oven do it for you.
Even if you work hardened the steel it will only be hard at the surface. A carbide tool bit will cut through that.
If this is your first time using a lathe, start with turning nylon or delrin. Then try aluminum, but make sure you have cutting fluid handy and keep the material good and wet.
04/25/2013 7:58 AM
....and I'd thought he was posting a 'weekend thread'. GA to you.
Good Answers: 141
04/25/2013 10:59 PM
It is also the only way to get most precision out of your lathe and less problems with
the cut-off material. Why?
First prize: the new Toss Lathe....... link.
Plenty of room here
Good Answers: 50
04/25/2013 7:45 AM
I didn't see anyone talk about the chuck mounting method on your lathe. If it's a threaded chuck, you never want to be cutting with it in reverse, as there is a high probability that it will spin off.
But as Anonymous hero has indicated, for left handed threads.
ignator -
04/25/2013 7:55 AM
I'm not quite sure what type of lathe you have, I'm assuming a wood lathe. I recall in my earlier years there where lather where you could turn larger object such as over sized bowls.
It's just that the thread had to be correct so your faceplate wouldn't fall off as your turning.
The there are accessories that you get for tool mountsfor this type of turning.
back in the 70's, our industrial arts dept. (Woodworking) in Junior high (7th-8th grade) had lathe like this.
Picture is only used for discription.
Also, if it is a wood lathe threading is done with a die.
If its a metal lathe there are plenty of application where it would have to run in reverse.
Good Answers: 458
04/26/2013 11:51 AM
Wow, the words 'industrial arts' brought back memories. Nobody calls it that these days. Too bad too. The current vernacular seems to be calling it the trades or vocational studies. There really is art to the process of making things and it's a damn shame "we" have lost sight of that as a society.
I took every shop class I could throughout junior high and high school because I loved working with my hands and making stuff. One part of the day I was banging around with the rough guys in shop class and another part of the day I was in AP calc or physics with the rest of the geeks.
And yes, that lathe looks EXACTLY like the ones we used in shop class.
Good Answers: 73
04/25/2013 7:56 AM
A glass lathe can run either direction. But it seems glass workers are a dying breed.
I guess you would have to call that "Not your ordinary lathe"!
Good Answers: 29
04/25/2013 12:46 PM
Drexel U here in the US used to have a glass shop right outside the lecture hall where I attened Physics I. The Chem department was down the hall, and I'm sure they used the glass shop extensively, most of the pieces that I saw were obviously intended for the chem lab. I do recall seeing them spinning parts in a lathe.
Good Answers: 119
04/26/2013 8:19 AM
Lathes in glass shops are indispensable for even heating and symmetrical drawing(lengthening) of cylindrical glass objects. The turning also helped nullify sagging due to gravity. We would regularly reverse the rotation so (as I was told) the glass would not take a "set". I never investigated that so I don't really know what that means. I just did as I was taught.
As an apprentice machinist at NASA in the 60's and 70's we were cycled through many of the different shops for exposure to other trades. One of those was our glass shop where I spent 3 months as an apprentice and another 6 months after I graduated. Back then, in the early days of lasers, we mostly made our own as we explored potential uses for them.
Those were the cool days of NASA.
Hooker
Re: Why Would You Want a Lathe to Run Backwards?
04/25/2013 10:56 AM
Reverse is a standard function on most every metal working lathe and mill.
Its used for a lot of things. High precision surface grinding in one. Threading is another.
Inside dia threading and boring are often done backwards as well putting the cutting tool at the back side of the workpiece.
Think about it for a bit. If the workpiece is spinning counter clockwise facing the chuck and you cut a thread where will your tool be traveling towards?
Now put it on the back side and spin it the other way. Now what happens if you overshoot your threads?
On my smithy 1340I I use reverse in about 1/4 of the things I do.
04/25/2013 11:46 AM
Thanks for all the replies guys (even the teasing, sniff)
For the record it's a Myford 7 metal turning lathe. My Dad has tons of kit for it, milling attachment, draws full of collets etc.
I have a tiny lathe myself which I've used for things like turning an arrowhead out of Antler, great stuff to turn.
I was hoping to turn a new headstock shaft on the Myford, but my enthusiasm outstripped my expertise. I'll do it next time I'm down there.
Shame I didn't get some tuition off my Dad when I was younger, but once I left home it was too late. Mind he taught me how to strip down an engine and re-build a Vespa scooter which was what I needed to know at 16 years old. (E.G. Vital for exploring the world and finding girls!)
04/25/2013 1:30 PM
It could be worse.
I had an idiot manger send back an order of 10 bandsaw blades along with a nasty note to to the manufacture because they were "manufactured inside out" and when put on our shop band saw the teeth would point the wrong way.
The thing was we had ordered 10 blades two weeks before and the box had shown up a day or two earlier. When us shop guys wore out the last blade we asked for one of the new ones.
At that point our manager said that when they came in he went to put a new one on and it was backwards. From there he checked all of them and they were all made that way so he said he wrote them nasty note regarding poor quality control and shipped the whole lot back for a refund.
BTW for those who don't know when bandsaw blades are shipped they are usually rolled up in a coil and you have a 50/50 chance of them flipping right side out or wrong side out when you uncoil them. If they land wrong way out you just give them a twist and pop them right side in!
04/25/2013 1:44 PM
Yeah, that had me foxed for a minute first time I came across the problem.
I put a blade on and the teeth were pointing up. I tried again and this time they were pointing down but at the back of the blade.
Then the penny dropped.
I popped it inside out and it was fine.
It took me ages to get the hang of re-coiling a blade when I wanted to swap from coarse to fine (I cheated and looked on Youtube to see how to do it). It's a good trick to show people who haven't seen it done.
04/25/2013 1:53 PM
But it's a nice feeling when you do get it......... and in front of someone is a bonus.
04/25/2013 1:54 PM
Clearly you are overqualified for a management position.
But then you didn't reason out why metalworking lathes would have a switch to make them run both ways so.... Maybe not?
04/25/2013 1:52 PM
Managers on a power trip
04/25/2013 1:55 PM
What fun times and good memories at the workplace are made from!
04/25/2013 2:37 PM
I rarely take vacation for the first 25 years in the work force.
But, friend of mine got married in Colorado Springs, and my dad needed help baling hay, so I took 10 work days off, Went to the wedding, afterwards on my way to my dads farm, I stopped at work to straighten out some issues.... about 6 hours.....
Anyways the owners nephew (Jason) took off the same time, when I got back, no one notice he was gone, Me on the other hand had to put in 70+ hours/ week for the next 2-3 months just to catch up, (math does not add up).
Anyways when I returned, Jason also returned after coming back from vacation anounced he had to take another week off...... poor lil' feller, work must be hard on him.
Things run really smooth when they're gone.
Good Answers: 88
04/25/2013 7:04 PM
A busted tool is not the worst thing that could happen, running lathe in reverse. Especially if your chuck or faceplate is threaded on lathe spindle as I understand was common attaching method for UK lathes. All it takes is a little tool biting, e voila, big iron wheel, chasing cat. S.M.
04/25/2013 7:12 PM
Very few metal working lathes have thread on chucks. Most have quick change cam lock types being that the machine is designed to run both ways at full power if needed plus it's fairly common to need to change out chucks during some machining processes.
Good Answers: 918
04/25/2013 9:13 PM
I think this particular lathe, the Myford 7, has a screw-on threaded spindle of 1-1/8" and not a cam-lock chuck.
04/25/2013 10:50 PM
I always thought you would run it in reverse if you wanted to work from the other side of the lathe or were left handed!
04/26/2013 2:42 AM
All good lathes have a reverse chuck direction.
1. For male RH thread cutting where you have a shoulder to cut the thread to, it's easier and safer to run a RH cutter at the back of the work (or LH cutter upside down if a centre is in use) and withdraw it than to try and stop before hitting the shoulder, for this action you need to reverse the chuck direction.
2. When cutting a female RH thread in a blind hole, it's safer to run backwards with a LH tool on the rear edge and withdraw than to risk bottoming out and breaking something. For a LH thread you would run the lathe in forward and front edge with a Rh cutter for the same reason.
3. For boring operations, running the lathe in reverse and using a left hand tool allows you to cut at the back of the bore rather than the front, and therefore have a better view of proceedings.
4. Many dome cutting attachments require that the lathe is running backwards to perform correctly.
04/26/2013 4:08 AM
When parting off it is a lot easier with the lathe in reverse and the tool upside down.
04/26/2013 5:48 AM
Many lathes have the parting tool upside down and coming in from the back with the lathe still turning in forward direction. The parting tool is generally left in this position constantly with the cross slide bringing it into play when wound right out.
04/26/2013 5:54 AM
This only works if you have a rear tool post. Most older lathes don't have these.
04/26/2013 4:43 AM
If its a metal turning lathe then parting off is usually done in reverse as it puts the thrust of the headstock bearings into the bed (against gravity) and not the reverse. i.e. parting tool upside dwon.
Oliver Dunthorne
Good Answers: 918
04/26/2013 7:23 AM
I have seen that, but the direction of force is opposite than what you describe.
The reason given for doing parting upside down is to let the chips drop off the blade, rather than accumulate.
04/26/2013 8:09 AM
I assure you it is nothing to do with the chips it is the force. If you do not believe me try it.
Oliver Dunthorne
Good Answers: 918
04/26/2013 10:29 AM
The force will be exactly equal, only the sense changes. It is simple physics. Or are you talking about the load on the outer race of the spindle bearing?
The other issue is that it is really better to have the turning force applied downward onto the tool anyway. That way the force is transferred downward onto the top of the ways instead of lifting the carriage off the ways.
04/26/2013 9:34 AM
Any machine tool will kill you, do not turn one on if you do not know how it works. Most have no safeties on power or feeds because they are designed for people smart enough to use them and to take the dumb ones out of the gene pool. Go to your local voc school and take a night class in basic machine tools. Lots of reasons to run a lathe backwards, feeding out from the chuck, reversing an internal tap. Some machines are stiffer on the back stroke. Too bad Dad didn't show you how to use it, some knowledge can make the difference between a maker and a taker.
04/26/2013 9:49 AM
There goes our appreticeship program shot to hell.
Good Answers: 119
04/26/2013 10:40 AM
"reversing an internal tap"
Or an external die...
Hooker
04/26/2013 9:47 AM
Many lathe processes run backwards like threading, boring processes, to cut corners, positioning, to make grooves in back faces, to make chamfers at the exit of the holes, etc.
Just imagine what can be done by imagining
04/26/2013 10:20 AM
Actually, while not common, depending on the tooling and operation performed it is not at all unusually to run a lathe spindle "backwards". Many lathes, especially for production applications have an easily accessable lever to reverse the spindle quickly, while others like yours use a switch to reverse the direction of the spindle motor.
04/26/2013 10:41 AM
what do you mean "not common"? Many CNC machines for production has two spindles, for second spindle the machine run backwards. In this types of machines are very common processes.
04/26/2013 8:17 PM
I've been thinking about inventing a lawnmower that runs backwards...for when you only want to punish the grass for growing so fast, but not really cut it.
Good Answers: 918
04/27/2013 7:44 AM
It could also punish you!
In reply to #66
04/27/2013 7:52 AM
It depends what he has in mind......
In reply to #66
04/27/2013 8:55 AM
Yet another weak attempt at humor...
I was wearing my Monte Python hat, and imagining an earth friendly lawnmower that just bent the grass over; followed by "greenies" standing in line to buy them.
In reply to #68
04/27/2013 10:18 AM
If you put the blade on upside down so the cutting edge is facing the wrong way and you reduce the engine RPM's it won't cut worth a darn.
In reply to #69
04/27/2013 12:09 PM
It would use way less fuel too. Another big selling point!
05/02/2013 11:25 AM
There is also a technique where you are cutting a thread and instead of disengaging the half nuts, you reverse the lathe and run the threading tool back to the beginning.
Mr.Ron from South Ms.
Good Answers: 119
In reply to #71
05/02/2013 11:53 AM
That's the way I was taught. You just have to remember to pull the threading tool out with the cross slide so slop in the feed lead screw doesn't cut away thread you need to have.
Then, increment the compound in and run another pass. Rinse, repeat.
Hooker
05/22/2013 8:36 AM
Hi Dell,
The lathe function requiring reversing the lathe's rotation is screwcutting worms (for worm gears) and metric threads on inch leadscrew lathes (or inch threads with metric leadscrew lathes).
With same measurement threading the leadscrew half nuts are opened after each cut, the saddle moved to the thread's start, and the chasing dial viewed. As the job and leadscrew rotate the chasing dial indicates when to re-engage the half nuts. This system is only workable for simple ratios between job and leadscrew pitches, so with your inch based Myford cutting metric threads it is best to keep the half nuts engaged to avoid cross threading. To return the tool to the thread's start the lathe has to be reversed.
You can use a crank handle in the back of the lathe's spindle but electricaly reversing is usual.Happy turning, Zaf.
Register to Reply 73 comments
Andy Germany (1); Anonymous Hero (5); BJInvention (1); Brave Sir Robin (1); bwilko (2); dhgrant (1); Doorman (2); dvmdsc (3); Hooker (4); ignator (1); indyrat500 (1); kramarat (3); Kris (11); Lo_Volt (1); Lvillar12 (2); Mizuti (1); NotUrOrdinaryJoe (1); Oliver Dunthorne (2); P.Mason (3); phoenix911 (6); PWSlack (2); Randall (2); ronseto (1); SimpleMind (1); Solararts (1); tcmtech (7); Tornado (1); user-deleted-1105 (4); wmerryall (1); Zaf (1)
