Previous in Forum: generator droop settings   Next in Forum: V=IR R=V/I I=V/R
8 comments
United States - Member - New Member Engineering Fields - Military Engineering - Member Engineering Fields - Mechanical Engineering - New Member
dc connector advice
05/30/2007 4:30 PM
Greetings all,
I'm currently looking for a quick disconnect connector (preferrably pins), that can be a push-pull connection (no threads). Similar to the motion on a pc power supply, or a cigarette connection. Somthing that is Fast to disconnect, but is hermetically sealed.
Does anyone have a company off-hand they would recommend, or experience with quick disconnects? I'm currently all over GS looking, and cant find anything that strikes me. I'm trying to find somthen off the shelf rather than have it custom.
Working electrical specs: 10A peak, 1.59A nominal, 35 W, 24VDC supply.
TIA for any search tips, or company suggestions.
Pathfinder Tags: connectors
United States - Member - New Member Engineering Fields - Chemical Engineering - New Member Hobbies - Musician - New Member
Re: dc connector advice
05/30/2007 4:39 PM
Have you tried Lemo?
Check this site out:
http://www.lemo.com/products/connector/index.jsp
Regards,
Mike
"Blessed is the man who, having nothing to say, abstains from giving us wordy evidence of the fact." George Eliot [Mary Ann Evans] (1819-1880)
05/30/2007 4:41 PM
Speak of the devil, i was Just looking at their site, :) thanks. They look pretty good
05/31/2007 11:25 AM
we also use LEMO..............high costs, and terrible lead times.....we only need small quantities......i wish there was an American source :(
05/31/2007 1:18 PM
Well that doesn't sound very inviting, any other manufacturer's you would recommend?
I've also found ODU USA, as another supplier.
05/31/2007 1:36 PM
don't let me talk you out of them, i was just venting..........give them a call and check them out yourself
05/31/2007 3:41 PM
Look with RS Components or Farnells. Have a wide range from a lot of manufacturers
Mapline <http://www.mapline.co.uk> if you are in UK. They are much cheaper than above 2.
Just for details:
Socket ? Chassis Mtd/ Free
Need: Bulk or a few pieces?
For OEM manufacture or occasional
06/02/2007 10:47 AM
Check out powerwerx.com.
The website loads pretty slowly but it's something. The connectors you would like are anderson powerpole.
Sean
11/22/2007 2:28 PM
Did you look for electricals in automobiles they too use such connectors with specs you mentioned above , i too use them in shanty , watery , industrial areas when required were sealing is utmost priority when connected and they are available readily in auto spares market with little expensive or you can search through what other members have supplied
Register to Reply 8 comments
cmnky26 (2); EVModules (1); Haajee (1); mikey (1); reefdiver (2); vikas (1)
