My friend is having trouble with her 2005 Mercedes C240 sedan. The car has 65K miles (very low for the year) and she has an intermittent parasitic drain on the battery. When she parks the car overnight, randomly the next morning the car won't start or cranks slowly. Here are the things that have been checked:
- Does not happen when parked at work (8 1/2 hours).
- Alternator is okay - car will start normal after shutting off, day or night.
- New battery installed - old one was weak, so a new one was installed about a week ago. Problem existed prior to new battery.
- No lights remain on - Both interior and exterior checked in a dark garage.
- All equipment is factory installed, including alarm system. Alarm does not trigger at night - car is in the garage.
- No sticking switches found. All were checked and none sticking.
- Taillight bulb warning message. Bulb not replaced, but I don't think this has anything to do with the parasitic drain.
- Tilt steering lever is damaged. Should have nothing to do with problem.
- Headlight switch set to automatic. One night it was moved to off with no improvement.
- Car was brought to the shop and shut off. Clamp on ammeter showed current flowing from battery lead. The next day the car needed a jump start. Since then, have not been able to duplicate problem. Car starts fine every morning.
- Car drives normal. All electrical equipment works fine. Keyless remote works intermittently.
I own a 2004 Mercedes C230 coupe and have not had problems with the battery or parasitic drain. I have heard that some cars have trouble with the alarm system after the car gets to a certain age. My gut feeling tells me this is the problem. My mechanic thinks it's the power seat module (suppose to be a common problem on C-Class cars). Anyone own this generation C-Class and have the same problem? Anyone have an idea of what is wrong?
