Previous in Forum: Turbine Low Load Operation - Below 50% MCR   Next in Forum: Gas Nozzle Size, Pressure, Flow Equation
Software Program for Cost Estimation
05/18/2013 2:53 AM
To make cost estimation of the components we manufacture, we generally use Microsoft excel all the times. An assembly drawing will have so many sub assembly drawings and detail drawings. To estimate cost it requires minimum of 1hour by studying the drawings, entering milling, drilling, grinding etc costs.
I was thinking of writing a programme which will have graphical user interface asking the inputs of not only the material cost but also manufacturing, design and inspection cost.
Can anybody suggest me the user friendly language so that I can learn it and develop for doing cost estimations. In that I should be able to use graphical user interface functions also.
Pathfinder Tags: cost estimation program
Engineering Fields - Mechanical Engineering - New Member Kenya - Member - New Member
Re: software program for cost estimation
05/18/2013 4:50 AM
I recommend MatLab.
I used a GUI to provide tabulation and tracking of variables in a homemade wind turbine. The setup I had plotted wind speed from an anemometer[m/s] and electricity being being generated [V] simultaneously on the same axes via a DAQ connected using RS-232 cables. This was very helpful in establishing performance characteristics and optimization conditions of blade design/pitch angle etc.
You could similarly play around with the GUI tool to suit your needs. As this video shows, there are many options and possibilities thus extremely customizable.
However, MatLab is an extremely powerful tool and may be overkill for your needs. Also, given the cost of the software perhaps there is a more suitable tool out there for your needs.
What about PDMworks which is used in conjunction with Solidworks? I am aware of its usage in document and Part No control. Perhaps the sub-assemblies could have the costing information you are tracking... Just a thought.
Good Luck.
Technology solves problems we didn't know existed, or didn't realise that they needed to be solved. Tinkering is therefore never pointless.
05/18/2013 5:41 AM
thank u,I will try matlab now.
i know matlab,i have used it in doing contact analysis using FEM. I know about GUI in that but never used it,actually i was thinking of javascript and all but this didn't flash on my mind.
can u give me some important or common GUI FUNCTIONS IN MATLAB.
Good Answers: 918
05/18/2013 7:29 AM
What CAD program are you using for design?
Typically, programs like Solidworks and Autodesk Inventor have these functions built in or as an add-on property.
05/18/2013 7:35 AM
CATIA V5 R20
Good Answers: 918
05/18/2013 10:25 AM
Maybe your CATIA representative might be a resource.
Also, you might try signing up with a CATIA user's forum. I am sure there are other users out there that have the same needs and it would be possible to get an idea what others are using or how they approach the problem.
Re: Software Program for Cost Estimation
05/21/2013 1:45 AM
Great piece of work thanks.I was looking for the same.
Register to Reply 6 comments
Anonymous Hero (2); bett4haze (1); litingtingsmile (1); Mehar314 (2)
