Previous in Forum: Welding Time Study (TIG Welding)   Next in Forum: Somebody Can Tell Me the Meaning of Lining-Dua Plate 8 on 6?
Hydrotest Limits on PID
05/19/2013 2:09 AM
Hi, I would appreciate any advice on setting the above limits and the proper procedure and if anyone knows of any good literature for explaining the above.
Many thx, John
Also posted in: also posted in Manufacturing
Re: Hydrotest Limits on PID
05/19/2013 3:14 AM
Good Answers: 34
05/22/2013 1:43 PM
Are you talking about piping systems?
Good Answers: 34
05/22/2013 2:10 PM
If YES:
Go to "Hydrostatic pressure testing of pipe, Engineering desing Guidelines" From KLM (Very nice)
ALSO:
P&ID shows all of piping including the physical sequence of branches, reducers, valves, equipment, instrumentation and control interlocks.
The P&ID are used to operate the process system.
A P&ID should include:
  • Instrumentation and designations
  • Mechanical equipment with names and numbers
  • All valves and their identifications
  • Process piping, sizes and identification
  • Miscellaneous - vents, drains, special fittings, sampling lines, reducers, increasers and swagers
  • Permanent start-up and flush lines
  • Flow directions
  • Interconnections references
  • Control inputs and outputs, interlocks
  • Interfaces for class changes
  • Seismic category
  • Quality level
  • Annunciation inputs
  • Computer control system input
  • Vendor and contractor interfaces
  • Identification of components and subsystems delivered by others
  • Intended physical sequence of the equipment
  • Equipment rating or capacity
This figure depict a very small and simplified P&ID:
A P&ID should not include:
  • Instrument root valves
  • control relays
  • manual switches
  • primary instrument tubing and valves
  • pressure temperature and flow data
  • elbow, tees and similar standard fittings
  • extensive explanatory notes
Regards, WP
Register to Reply 3 comments
