Previous in Forum: Pressure Drop in Compressed Air Line   Next in Forum: Paint on a Awning/Shade
21 comments
Torque Converter Oil
05/20/2013 2:59 PM
Hello....I will apprecaite if anybody would like to tell me the oil that is use into a torque converter of a backhoe Case 580 Super E...
Thanks an advance
With all due respect
Good Answers: 1693
Re: Torque Converter Oil
05/20/2013 3:14 PM
Regular automobiles use transmission fluid. Don't know about tractors.
Tractors - Case IH
Case Tractor Parts, Specs and Information - Yesterday's Tractors
05/20/2013 3:33 PM
Case TCH Fluid or Case Hy-Tran ULTRA
Not sure what non Case brand equivalents would be.
05/20/2013 3:36 PM
It is common to say here the number, meaning, sae 40, sae 90, sae 150, etc.
Good Answers: 104
05/20/2013 4:24 PM
Those numbers just denote viscosity range.
There's a lot more to hydraulic/transmission/torque converter fluid than viscosity. I think a 580 has 3 to 5 hydraulic and lubrication systems. You need an owner's manual to make sure you get the right amount of the right lubricant in the right place. Or call a dealer. A small error can be very costly.
Good Answers: 1693
05/20/2013 5:36 PM
05/20/2013 6:06 PM
Our case 1150 track loader uses any standard hy-tran type universal hydraulic transmission oil or automatic transmission fluid so the odds are your CAse 580 uses the same or will work just fine with the same type of fluids.
If your machine is like ours you have two different hydraulic systems and because of that I add about 1/4 automatic transmission fluid in with the hy-tran fluid to give it a light red color.
The main purpose adding the automatic transmission fluid is to just give the hy-tran fluid a red tint so it's easier to tell which system is dripping and from where.
05/20/2013 6:13 PM
Lynnn: I looked at Case Tractor parts...did not find anything....Tcmtech, you are the 3th oppinion saying the same...just trasmission red oil. I will use that one. Thank you all very much
Good Answers: 1693
05/20/2013 7:04 PM
All ya gotta do is look.
580SR, right?
AKCELA and CASE - Home -
So we recommend:
GroupProductCapacity
ENGINE COOLING SYSTEM
AKCELA PREMIUM ANTI-FREEZE
24
Notes:
  • BLEND WITH 50% OF WATER
OIL SUMP AND FILTER
AKCELA NO.1 ENGINE OIL 15W-40
Notes:
  • For 2WS: 14 l; for 4WS: 12,8 l
BRAKES
AKCELA LHM FLUID
1
FRONT AXLE
NESSUN PRODOTTO
Notes:
  • For 2WS: use AKCELA Hy-Tran Ultra 6,5 l. For 4WS: use AKCELA NEXPLORE 10,5 l
REAR AXLE
NESSUN PRODOTTO
Notes:
  • For 2WS: use AKCELA Hy-Tran Ultra 21,2 l with AOA additive 0,8 l. For 4WS: use AKCELA Nexplore 11 l
POWERSHIFT TRANSMISSION
AKCELA TRANS XHD SAE 10W
14
POWERSHUTTLE TRANSMISSION
AKCELA NEXPLORE
18
TELEVATOR ELONGATED ARM
AKCELA MOLY GREASE
Notes:
  • ACCORDING TO NECESSITY
FRONT WHEEL HUBS
AKCELA HY-TRAN ULTRA
0,2
Notes:
  • EACH
HYDRAULIC SYSTEM
AKCELA NEXPLORE
Notes:
  • For 2WS 140 l; For 4WS 118 l.
GENERAL GREASING
AKCELA MULTI-PURPOSE GREASE 251H EP
Notes:
SIDE REDUCTION UNITS
NESSUN PRODOTTO
Notes:
  • For 2WS front axle: use AKCELA Hy-Tran Ultra 0,7 l (each). For 4WS front axle: use AKCELA Nexplore 1,3 l (each). For 4WS rear axle: use AKCELA Nexplore 1,3 l (each)
05/20/2013 7:14 PM
Mrs Lyn...Thank you very much...a allways you are smartt and proffesional...I appreciate a lot.
Good Answers: 1693
05/20/2013 7:20 PM
Happy to help.
Just for the record, it's Mr. Lyn
05/20/2013 7:53 PM
That's not what everyone else refers to you as.
Good Answers: 1693
05/20/2013 8:09 PM
Yes, and it's still Mr. As$hole to you.
05/20/2013 8:14 PM
Ah thats better. Now we know who you are.
It still beats being 'Anonymous poster #1' or such.
Good Answers: 1693
05/20/2013 8:20 PM
Amen, brother!
05/20/2013 10:36 PM
Ask Case.
05/21/2013 3:38 AM
Absolutely. It may even be in the user manual that the OP received with it. Unless it got blown away in a tornado or something in which case, all the OP has to do is pick up the 'phone! "Rickenbacker! Good grief!"
Belgium - Member - New Member
Good Answers: 21
05/21/2013 7:05 AM
The level of torque can be controlled by adding more or less oil.
05/21/2013 11:40 AM
Until the transmission burns up a short time later from lack of proper lubrication and cooling.
Good Answers: 21
05/22/2013 4:57 AM
As far as I know, the torque is being transmitted by oil. The system consist of two fans placed in closed container. A driving fan makes the oil circulating and a driven fan moves with the oil.
This means when there is no oil, no torque can be transmitted. No torque, no warming up….
Good Answers: 1693
05/22/2013 8:49 AM
Rudy,
Suggest you research hydraulic pumps and systems. So far, both of your statements are incorrect and misleading.
05/21/2013 2:05 PM
Thank all of you...I already decide to use 10w-20...as trassmission oil...the red one...I'll be cheking the torque converter performance...if anyhing wrong, I wll advice you. Thnaks again.
Register to Reply 21 comments
bigg (1); JPool (1); lyn (7); Oraka (1); PWSlack (1); rudy.leurs (2); tcmtech (4); YUMASQ (4)
