For the past couple of years, one of the units that we produce consistantly gets returned with the complaint that the motor has jammed. I have finally been able to get to take a close look at the failed motors, and I've noticed that there is some kind of "gel" that has formed between the bushing and the shaft, which is locking it in place.
We are using spherical, self-aligning bronze sintered bushings in an application where speed ranges from 300 RPM - 1600 RPM. Bushing temperatures can reach 150°C in higher load scenarios. We use a mobil 626 SHC, which is well within spec for these operating conditions.
Here are some pictures of the substance under the microscope. It looks like it is a conglomorate of oil, particles that have been rubbed off of the bushing, and fibers from the felt pad. Has anyone else seen a problem like this?
-Mike
