Previous in Forum: LP Panel Testing   Next in Forum: Strange Alternator Problem
Engineering Fields - Piping Design Engineering - New Member
Selection of Isolation Transformer 80 KVA 3 Phase
05/23/2013 5:04 AM
Dear All,
We want to purchase isolation transformer (80 KVA, 1:1 ratio, 3 phase). Please guide me technical parameters to select the right one from different supplier.
Thanks for support in advance.
Re: Selection of Isolation transformer 80 KVA 3 phase
05/23/2013 5:40 AM
  • Voltage
  • Size
  • Weight
  • Mounting arrangement detail
  • Lifting arrangements
  • Termination detail
  • Circuit protection detail
  • Earthing detail
  • Ingress protection detail
  • Ambient temperature/pressure/climatic conditions
  • Shipping and delivery detail
  • Standardisation compatibility for spares and servicing
  • Colour
  • Noise
to name a few.
Re: Selection of Isolation Transformer 80 KVA 3 Phase
05/23/2013 3:27 PM
Also applicable electrical standards the transformer is built and tested to.
Warranty.
Cost.
If you are lucky you can buy a pre-built product, if not (or you have special requirements) then you will need to get a transformer company to manufacture one.
05/24/2013 12:16 AM
I think this is in continuation of your earlier thread. If so, in addition to other specs already pointed out, you will have to specify vector grouping and delta/ star configuration. If sensitive equipments are connected down stream, you may also consider to include additional earth shield for the isolation transformer. Also depending on where you propose to locate the transformer, you have to specify whether oil or air cooled ( natural or forced ) type. The cable entry points will determine whether you want system built to take top or bottom entries of cables. Neutral point terminal and conductor to be designed for 2 times the rating of phase conductors. Also power control MCCB's for both incoming & outgoing side to be included, either integrated into the unit or as standalone units.
Register to Reply 3 comments
jack of all trades (1); Pattabhiraman (1); PWSlack (1)
