Did you all see the pictures inside the Plaza Elementary school in Moore , OK.?
Did you notice what was standing upright in most of the rooms pictured?
THE DESKS.
Ok, Not an absolute sealed enclosure, however much better than huddling against a wall, completely exposed, with your hands over your head.
Why not build preset rows of tables ( remember those old heavy black tables we had in Chemistry lab).
I envision ones with 3/4" steel tops, 1-1/4" dia. steel legs which are set IN THE FOUNDATION. You can add formica covering for looks if desired.
. . . wall collapses, ceiling collapses 3/4" sheet steel on a set of 1-1/4" steel legs will hold a lot of weight. Its simple, its easily accessable and it is extremely easy to escape from after...PLUS.... small chance of drowning in a water soaked room when all you need to do is find some where along the table to crawl out from under.
Flying debris inside the room? Ok. But I'd rather get hit with some shattered glass or splinters than a have a concrete block wall fall on me...( or a child).
Just a thought.
