Previous in Forum: Strange Alternator Problem   Next in Forum: (AC & DC )High voltage
16 comments
Good Answers: 54
Diode Failure
05/23/2013 3:25 PM
Does anyone know if this is possible (regarding a power diode). When a diode fails, typically it does so catastrophically (stops being a diode). What happens when a diode partially fails.
If a diode is leaking current when in reverse polarity mode, what is happening internally? Is it something that should happen every time or can it be an intermittent failure? If leaking current in reverse polarity mode, is it possible for the power to be pulled, then reapplied and the leakage stops?
This has me puzzled!
Thanks in advance.
This discussion was "closed" on 05/24/2013 11:25 AM. No new comments are allowed.
Message from admins:
Multiple threads
Re: Diode Failure
05/23/2013 3:37 PM
Failing short circuit is also common, then the diode becomes a resistor.
I don't think I have ever seen a partial failure before but I think leakage current can increase outside component specifications in some circumstances if it is operated outside its limits (over temperature or over voltage possibly).
What type and model of diode are we talking about and what is the application?
Good Answers: 54
Re: Diode Failure
05/23/2013 4:51 PM
Jack, You're right about diode usage outside of specs, but this is in spec. The diode is part of a bridge rectifier in an alternator. The voltage is within spec and ditto for the temperature.
The strange thing is when the battery is connected and the ignition is off, we get a 1.4A drain through the alternator. When the alternator lead is pulled, the drain goes away, but when it is reconnected, the drain is also gone. I'm thinking that a partially failed diode would consistently leak current.
The only other option is that the computer is somehow allowing current to leak through the alternator, but we can't figure out how this is happening. Any ideas?
Re: Diode Failure
05/23/2013 6:36 PM
I advise you perform a diode check of the bridge rectifier to see if you have got a diode that has failed short circuit.
Re: Diode Failure
05/23/2013 4:01 PM
They can leak, they can short, they can open circuit...
http://www.youtube.com/watch?v=xgikeXt91vM
Good Answers: 804
Re: Diode Failure
05/23/2013 5:22 PM
They all "leak", there is no such thing as a perfect solid state device, hence the term "semiconductor". The definition of a shorted diode is that the leakage is higher than specified.
I have never seen a diode go open circuit, it would basically have to be vaporized for that to happen. Probably really small ones used on PCBs that can happen though, I have just never seen it.
Side note: if you are testing "hockey puck" style diodes, they must be fully clamped into the heat sinks before taking measurements across them, the clamping pressure is part of the design specs.
Good Answers: 54
Re: Diode Failure
05/23/2013 7:19 PM
A leak of 1.4 A is quite a bit - not in the mA range for sure. I don't know if it's possible for a diode to leak that much without burning out.
In high school, we burned out some diodes to the point where they popped or cracked in half. We didn't know much about them, as they came in kits we bought and assembled in class.
Good Answers: 11
Re: Diode Failure
05/23/2013 9:49 PM
The alternator has a field.
Could the field be energized all the time?
Can you remove one of the alternator brushes and see if there is current in the field?
Good Answers: 54
Re: Diode Failure
05/24/2013 1:14 AM
This is possible, but would it draw 1.4A? If so, then the voltage regulator is malfunctioning, right?
United States - Member - New Member Hobbies - HAM Radio - AC9JZ extra
Re: Diode Failure
05/24/2013 10:11 AM
Good answer! The field is in series with an alternator lamp on the dash. If the ignition is turned on, but the car is not started, the light should be lit. This should be in the MA range, not as high as 1.4A. Could there be a short in the dash wiring?
The only dumb question is the one you didn't ask.
Re: Diode Failure
05/23/2013 10:50 PM
Most of my experience tells me there are only two failure modes for a diode -
Dead short - zero resistance and usually a blown fuse.
Open - no current, circuit has no voltage.
Leakage is part of a diode, agree semi-conductor, but failure always seems to be all or nothing.
Good Answers: 54
Re: Diode Failure
05/24/2013 1:16 AM
Thanks Sid, I think you're correct, but I remember way back in physics class - I recall hearing of a diode being partially dead, but not completely. Of course this is physics where the improbable is analyzed.
Good Answers: 119
Re: Diode Failure
05/24/2013 12:10 AM
Defective voltage regulator.
(edit: I see this was already suggested in a duplicate thread.)
Good Answers: 54
Re: Diode Failure
05/24/2013 1:35 AM
I think you're right. The problem is the alt is over $600, because it needs to be a MBZ part, not a reman. I have a test set up and I'll let you guys know how it works out.
Thanks for your help.
Re: Diode Failure
05/24/2013 6:15 AM
Sounds like SCR latchup
Re: Diode Failure
05/24/2013 10:56 AM
Why are you having two blogs open for the same problem? You are just wasting our time.
Decide which one you don't need.
Re: Diode Failure
05/24/2013 11:27 AM
Moderator Notice:
This thread has been closed because it is a duplicate discussion. Please continue this discussion under Autobroker's post Strange Alternator Problem.
HUSH
Register to Reply 16 comments
Multiple threads
Andy Germany (1); Autobroker (5); Carl Pugh (1); HUSH (1); jack of all trades (2); JRaef (1); Mike Proctor (1); mjb1962853 (1); Randall (1); Sid_Sidow (1); SolarEagle (1)
