I have several VW Diesel Passat and Jetta. I drive a lot and I use it as my office I am away so much. I have several devices such as a small refrigerator and two computers I have running ( I am a software developer and I give the computers jobs to do as I am driving). I did not realize that this draw would burn out the diaodes on my Stock Alternator. But it does after a while especialy on a hot day with the air conditoning on in stop and go 90 to 100 degree heat. The rating I am told is 120 AMPs and others say it is 140 AMPs. Regardless I read on line in more than one place that the rating is a peak rating and depending on the brand that the real load it can handle on a contiued bases is about 40% of the rating. Some may be good for 60% continues. There are high capacity Alternators on the market. However I can not find one small enough to fit my car. under heavyer loads than I normaly use the wires and other parts of the electrical system are fine. The battery I think takes a bit of a beating at stop and go trafic as I it must have to put out some to keep things going if the engine is at iddel with all the stuff running.
The Alternator is small with no fan or if there is a fan it is internal. There is just no place and no room for a larger size or a second Alternator that was sugested by one of the mfg companys.
Does anyone know of a place where I can get somone to change the parts in my alternator to give it a continues 120 or better yet 140 AMPs???
Or someone that sells one that would fit.
I have looked and do not see such a service. But someone somewhere has the tools to use better coils and magnets and diodes.
I may have an inch to play with in size so a larger fan could be used.
Any ideas of ANY kind would be helpfull. I even thought about putting a gas honda generator in the trunk with the pipes for exhoust and intake coming out the bottom
and even a housing for it. But the best way is to have a better quality than what is on it from the factory. It will go out again. I carry and extra with me but it takes time to get it changed and also costs about $600 and Some folks do not do a little damage to the car when they make the change. I do not mind the $600 but I do mind the fact that it can go bad in the night or on weekends and I can not get someone to fix it.
ANY ideas are wellcome.
Jim
