Leaving a notebook plugged into AC power all the time really shortens the life of a notebooks battery. A known fact, correct?
How hard would it be to make a battery saver: The box would consist of a timer, 2 relays and a small circuit board to read voltage from the notebook side of the box. It wouldn't even have to be a circuit board would it? Just something that reads a preset voltage and opens/closes a relay circuit. Call it the NBSC (Notebook Battery Saver/Conditioner)
Plug the cord from the NBSC into the notebook and the circuit would read the battery voltage. The circuit would have a range of values that could be chosen, and a person would choose a value just above where the manufacturer has the notebook go into standby or hybernates.
When THAT voltage was reached, it would close the relay on the AC side of the NBSC (the DC wire coming from the AC adapter - ACDCWire) and start the countdown timer which is hooked into the ACDCWire relay. The timer also would be adjustable (in maybe 15 minute increments). If it took 1 hour and 20 minutes to charge a discharged battery, the timer could be set for 1 hour and 30 minutes to make sure the battery was topped off.
At the end of 1 hour and 30 minutes the timer would open the relay on the ACDCWire side of the NBSC and voltage would again be read from the notebook side of the NBSC. It would NOT matter how long it took the battery to discharge, since the charging circuit wouldn't close until it reached the preset discharged voltage you had selected. Then the timer circuit would close and the battery would be charged again.
In fact, the NBSC could just have a receptacle matching the notebooks. You would just plug the AC adapter DC cord into the NBSC and out the other side of the NBSC would be a cord with an end on it like comes on the AC adapter, just plug that into the notebook.
Make one for $10-$15 and unplug the notebook cord, plug it into the NBSC, plug the NBSC cord into the notebook. Let the NBSC greatly extend the life of your notebook battery. Much better than being in the charge mode all the time (like I have them now).
Probably could be made with 1 voltage switch, 1 relay and 1 timer. How hard would that be to breadboard together? Wouldn't that work?
Is there one available on the market already? What kind of cost?
Thanks,
Ken
