One 45 tons/hr spreader stoker fired boiler had an explosion with a loud noise causing furnace water wall damage.
Details are as below:
Boiler parameters 45 tons/hour; 65 kg/cm2; 490 c
Fuel - eucalyptus bark.
Type – balance draft (-5mm) with travelling grate
Auto controls – 3 element feed water control, steam temperature control, combustion control, furnace draft control
Control system – dcs
It is understood from log sheets and operators that during the period of explosion:
Fuel feeding was manual and also excessive fuel feeding was done
Furnace pressure was contnuouly positive to the extent of +5mm
Analyer indicates high oxygen content in flue gas (may be instrument error)
The forum can evaluate/discuss the above problem on:
What could be the reason for this explosion in a stoker fired
Boiler with bark firing?.
What are remedies/precautions to be taken to avoid future occurrence of this kind of explosion?
