Hello, I'm having a problem converting a blown film line from producing HDPE (originally) to LLDPE. I've substituted the material, lowered the heating temperature in the die and screw to approximately 170 degrees, yet the results are that the 'bubble' is unstable. I've turned off the original air ring, which originally blows air from the side of the die and fabricated a cooling ring to sit approximately .5 meter above the die head, so the material exiting the die isn't being exposed to cool air straight away. Is this the correct way?
Another question is, is there a difference in the construction of the die for processing HDPE vs LLDPE resins? Is there a difference in spiral angle and the material inlet into the spiral?
I've also fabricated a custom mandrel so that the die gap will be smaller, however all this seems to do is add pressure before and after the screen in the extruder. One more bit of info, now that I'm utilizing LLDPE resins, the shape of the bubble upon exit of the die doesn't have the characteristic widening ratio of 3:1, I can achieve only a 2:1 ratio out of the die.
I'm hoping some of you might have some information on how to convert HDPE blown film lines to LLDPE or have some experience in converting materials and would be willing to share.
Thanks alot ^^
