Previous in Blog: US Plans To Restrict In-Car Tech   Next in Blog: Using First Person Shooting Games to Improve Vision
5 comments
Rubber Makes Buildings 'Invisible' To Quakes
Posted February 17, 2012 10:26 AM
From Discovery News - Top Stories:
An 'invisibility cloak' of rubber bumpers can send ground vibrations around buildings, keeping them intact.
Good Answers: 179
Re: Rubber Makes Buildings 'Invisible' To Quakes
02/18/2012 10:03 AM
I really don't see how this will effectively work if the building is constructed on saturated soils and landfilled areas.....these types of soils tend to liquefy (much like "quicksand") underneath the structure during earthquake events, and hence rendering normal bearing foundations totally useless......collapse of structure will result.
Not enough information given in the article IMO.....did they try rubber bladder isolators under the foundations and analyze/verify the results using the shake table?????
02/18/2012 10:53 AM
I've read this several times, and just don't understand what they are trying to say. The article didn't even get into the different types of movement that can occur during a quake, p/s/t waves and all that. This topic has been on CR4 many times (an especially interesting challenge question amongst them). The explanation of this 'inovation' could be better.
Location: East of Seattle, Washington state Republic of the 50 states of America
02/18/2012 2:46 PM
Maybe they are going to float it in a rubber barge!-) Liquefaction is a mass density, center of gravity and uniformity of stress issues. Sure you can stop the perceived shaking but if only half the basement liquefies on a taller building will it still stand?
02/18/2012 3:03 PM
They left out one very important issue.
They are talking about installing a density change barrier to channel the pressure waves, from an earth quake, around the building.
Much like a rock in a stream. That is fine for the building but the neighbors are going to get amplified waves and get hit much harder. Between two such buildings a focal point can form and you get the rouge wave syndrome at many orders of magnitude over the unhindered wave.
Fine for a building but not for a city. And if you do this on a city scale I do not want to live in the same state.
Good Answers: 179
02/18/2012 9:47 PM
Both Kris and UV have made some solid valid points here....GA for both!
CaptMoosie (2); Kris (1); U V (2)
