Building & Design Blog Blog
The Building & Design Blog is the place for conversation and discussion about building projects, tools and equipment, materials and hardware, and environment & energy. Here, you'll find everything from application ideas, to news and industry trends, to hot topics and cutting edge innovations.
Previous in Blog: Staying Green Keeps in the Black   Next in Blog: Jakob's Green Ladder
4 comments
Tokyo's Tall Green Order
Posted February 10, 2010 7:55 AM
While cities like Dubai build giant high-rises by choice, other cities like Tokyo, Japan build skyscrapers out of necessity. Simply said, there's no more land to go around.
With every available piece of property developed in the congested city, the Japanese have seen their average annual temperature increase by more than three degrees. This so-called "heat island effect" has alarmed the city's metropolitan government to impose a new rule regarding new and rehabilitative commercial construction. All buildings must go green.This means that the owners and developers of Tokyo's concrete jungle must submit plans for the inclusion of rooftop gardens, lawns, trees and other plants along with their architectural design documents to city officials before being granted a building permit.
Japanese Architect Kenji Ichinomiya, who studied at the U.S.'s Frank Loyd Wright Taliesin Institute, welcomes the government-mandated green initiative. "Buildings go up and up," he says. "But if we can make artificial 'ground' on the rooftops and cover them with plants, this will make a better environment for everyone. And new technology is so developed, we can now build rooftops that won't leak."
My dad has been building commercial buildings for nearly three generations now, and he has yet to come across a roof that won't leak, even when it doesn't have a layer of soil laid on top of it. However, if what Ichinomiya states is correct and a unique leak-free tech is being developed for these new green rooftops, then the Japanese could be on to a green and sustainable idea that might just become the standard for the rest of the world to follow.
But how much cost would be added to a commercial design by making the rooftops not only green, but by instituting the leak-free technology to make them work? How much will it cost to maintain the roofscapes? Should government's mandate green rooftops for high-rises? Or should it remain the choice of the developer or owner?
The preceding article is a "sneak peek" from Building & Design, a newsletter from GlobalSpec. To stay up-to-date and informed on industry trends, products, and technologies, subscribe to Building & Design today.
Good Answers: 42
Re: Tokyo's Tall Green Order
02/12/2010 11:34 AM
The last surface greenary can be best compensated by roof gardens only.
It has additional benefits of cultivation possibilities.
*buildings should also have hollow floorings intermittently to render free air passage.
Black bitumen roads need consideration along with trees at sides to compensate for the heat absortin.
Present generations ruthlessly cut away valuable trees and greenary for the sack of existance.
Barren walls can also support creepers. can it be?
Nature is so graceful and naked. Human possession is ridiculous.
02/17/2010 7:02 AM
...he has yet to come across a roof that won't leak,...
Worked for Leighton Contractors many years ago and their head office had a "water roof". The roof was a pond about 2' deep.
If you went up there, there were a few stalactites growing, but overall it was surprisingly water proof and effective. Cut the air conditioning load substantially.
Roof top gardens not only reduce air conditioning load, they provide a pleasant place for people to relax.
Once, when I was gliding, I noticed the big difference to local air temps made by a belt of greenery just before the runway. The glider sank rapidly and noticeably as it passed over that region. One pilot underestimated the effect (or didn't know it would happen) and actually wound up landing before the runway, ending up just at it's start!
If this could be extended over the majority of a city, it could significantly reduce the "heat island" effect. It is always going to be tough compensating for the temperature rise caused by all the bitumen needed in a modern city.
02/19/2010 5:36 PM
I think it is time to enforce a green regulation, we have the ability and technology. It is laziness and lack of education that prevents it from being used, and when it is used the price triples?
I just dont want this false greeness that is currently active to be the basis for our future standards.
Green should be based on 100% of the companies work and description not the 3 - 5 % that is the standard now. (eg. if some one says they are building a green door and they are not re-using a door that has been re-claimed then they do not qualify to be green. Just because they use sustainable materials should not be automaic qualification.Being green is a start to finish qualification, not just a one step out of 200.)
02/22/2010 7:27 AM
I think it is time to enforce a green regulation,...
That's like using a sledge hammer to crack a peanut.
Allow the advantages of sensible green engineering to be used, and it's advantages will have it in place wherever it is appropriate, avoiding the inappropriate uses which would be foisted on us if forced by regulation.
Advantages are usually along the lines of aesthetics, reduced cooling load, improved comfort (hence enhanced saleability) sometimes even reduced cost. I'm sure more advantages can be found but they need to be examined on a case by case basis.
Removal of some of the more restrictive regulations would far help more than extra regulations, but these will vary from place to place.
Anonymous Poster (1); s.udhayamarthandan (1); sceptic (2)
